IH crawler gas motor fuel pump
/ IH crawler gas motor fuel pump #1
Modrob
Gold Member
Power Trac
Curious…1950 International Crawler with c-248 motor (similar to Farmall M)…can an electric fuel pump replace the mechanical Model B?
/ IH crawler gas motor fuel pump #2
I don't know. What type of fuel system does it have?
If it is a float type carb, then yes, you can purchase a electric fuel pump that has a low pressure output. No more than 3 lbs.
Richard
Richard
Gas system, and yes, float carb…many thanks. 😊
/ IH crawler gas motor fuel pump #4
Was it originally a gravity feed carb or did it have a mechanical fuel pump? Either way electric should work but like Richard states must be low pressure especially if was gravity feed.
As of now it’s still original—tank behind operator and tapped on bottom, line runs from there under floor, out firewall and into a mechanical fuel pump and sediment bowl, then up a few inches into the float carb. Nothing bad yet so I’ll keep using but I have a feeling it may crap out soon. Hard to find, and if found, EXPENSIVE.
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
832754 (A61166)
832754 (A61166)
NexTier Frac Manifold T/A Trailer (A60352)
NexTier Frac...
2021 CATERPILLAR 306CR EXCAVATOR (A62129)
2021 CATERPILLAR...
1018 (A61165)
1018 (A61165)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
