YM2210-B block heater install
/ YM2210-B block heater install #1
thehohoman
Phil Campbell, Al
Yanmar 2210D
I have an older 1970s model YM2210B and in need of information and location to put in a block heater. I am having an issue locating a threaded hole for the heater. Any locations or video would help greatly.
Thanks Frank
/ YM2210-B block heater install #2
Is the threaded heater you bought specifically for your model tractor? Not all engines are going to have a threaded plug in the block. All will have freeze plugs, where the majority of block heaters are installed.
/ YM2210-B block heater install #3
I don't think I have ever seen a threaded coolant plug on a YM2210 block. Many of the 3 cylinder Yanmars have them but, for some reason, most of the 2 cylinders don't. The freeze plug holes are typically too shallow for a block heater. I have seen some freeze plug extension tubes on ebay (for Kubota I think) but I'm just not sure if I would trust them to stay in there. I'm sure they must work but looks suspicious to me.
Many years ago I made a few batches of water pump back plates that had a small block heater threaded into it but that block heater was discontinued and we could not ever find another one thin enough to screw into that plate.
(edit: I found a picture of the custom water pump back plate in case anyone was interested)
Aaron
No, sir, I haven't purchased one yet. I wanted to see what the options were as to where to put one. She is a tough cookie to crank when cold. Have you had any experience with the magnetic types?
Aaron
Thanks, Aaron, I really didst want to punch a plug out and have a problem getting it sealed back up. I might try a magnetic type. If you have any history of those, I'd appreciate any info. Thanks.
/ YM2210-B block heater install #6
Someone here probably has personal experience with them and can help better but the general feedback I have received on the magnetic heaters is that they work fine unless it gets really cold. If you throw a heavy blanket over the engine it will help a lot too.
Aaron
/ YM2210-B block heater install #7
They make heaters that mount on your radiator hose too.
Just cut the hose and clamp it on. I use to have one on my Mitsubishi tractor.
They probably work just the same. (maybe) :unsure:
/ YM2210-B block heater install #8
You can get one that goes in the bottom radiator hose.
/ YM2210-B block heater install #9
Not on Yanmars, but I know folks who like the Wolverine brand silicone heaters.
Does your YM2210B have a thermostart in it? (Near the top of the intake manifold?) If so, does it help?
All the best, Peter
/ YM2210-B block heater install #10
Thanks Frank
Yanmar 2T90 has a plug in the block, item-45.
Could this be used? I do not know.
For the YM 3-digit models with the 2 cylinders having a plug like this,
Again, on the 2TR13 and upwards,
From the YM165 parts manual
/ YM2210-B block heater install #12
I'm showing a thermal start start for a 2210. Same one on my 2000. It does help. I don't have the cold start problem now. I reconditioned a old gas ford tractor. Carb. and choke. But I had to deal with it for decades with only the Yanmar.
TE-1520 Thermostart plug. I've seen this before and be careful. Not knowing the 2002,2020,2202,2220 Etc. uses it. But a different style Thermostart plug for the 2210. It's listed under the old TE-4450. YM2000 Etc.
If I was in cold climate I would most likely have a Elec, heater also. You can tell a big difference When your have to "cold start it". Grandfather used a Light Bulb and and a Blanket! Old Chevy's. Mtns. of WV.. In the 1960's.
I would try the hose heater. IMO. Block damage and don't want to risk it!
YM2000 location and no Reservoir. I squirt some fuel to it if I would have to use it.
/ YM2210-B block heater install #13
