Pallet fork choice
/ Pallet fork choice #1
SRSeedBurners
Pottsboro, Texas
Kubota M8540
I have a Kubota M8540. I'm looking at the Express Steel 48" heavy forks that seem to be a match for my 6400lb lift capacity. Not that I'll ever lift that much. The ES, however, lack the receiver hitch and hay spear sleeves which I would really like. I see they come on Titan/Palletforks.com units. Any others out there I can consider? Not a fan of the chinese built from Titan although they do have some pricier 'made in the USA' units. Not sure how much I trust that either.
/ Pallet fork choice #3
I have the Land Pride PFL3048 pallet forks and have been very satisfied with them. Land Pride has the PFL6448 or PFL6460 pallet forks for your tractor. Both are 6400# capacity and either 48" or 60" length. For me the 48" length does everything I need. I have separate hay spears and a trailer receiver hitch plate.
Land Pride
Land Pride
Does the separate hay spears and receiver hitch plate attach to the pallet fork or completely separate unit?
/ Pallet fork choice #5
Stay away from Titan. They are cheap, but a disreputable company. They used the Titan name and moved their US mailing address to TN to mimic an actual mfg. It got so bad, the mfg changed their name to Ironcraft to avoid being associated with the cheap Chinese importer and imposter.
/ Pallet fork choice #6
Stay away from Titan. They are cheap, but a disreputable company. They used the Titan name and moves their US mailing address to TN to mimic an actual mfg. It got so bad, the mfg changed their name to Ironcraft to avoid being associated with the cheap Chinese importer and imposter.
I agree 100%, and would never do business with them.
/ Pallet fork choice #8
I would not want to have to be taking the forks off of the frame. 5500 lb 48"x5'x1.75" forks weight 130 lbs a piece.
I would not want to have to remove two 130 lb forks to use a receiver or a hay spear. If moving bales I would just use the forks. Below is a thread discussing this.
If you want a receiver consider getting a reciever mount for the forks.
If the trailers are really light then here is an option. I use one of these to move implements around in barns. For moving light stuff like empty hay wagons and smaller implements they are great. You can keep it in the cab of the tractor and just toss it on the skidsteer plate when you need it.
If you have a LA1353 then you can lift 5137 lbs to full height at the pins and 3957 lbs 1500mm forward of pins. So 6000lbs forks (rated at 24" load center) are more than adequate.
Express Steel makes some nice products. My one friend has a set of their forks. Another brand to consider is Stout, they are made in WI. Skid Steer Pallet Forks | Skid Steer Forks | Stout Buckets
The bale spear socket on the Titan units are for small tines that do not hold up well to frequent use. I have a Titan 60" frame and would never consider using it as a bale spear. I use it infrequently as it has 72" forks on it.
/ Pallet fork choice #9
Easy peasy. Just let gravity do the heavy work. All you have to do is guide them into position.
/ Pallet fork choice #10
Separate units. The hay spear is the Land Pride BS20 with twin bale spears. The trailer mover is the Titan receiver mount plate.
/ Pallet fork choice #11
I have a set of the Titan forks/hay spear that came with a tractor I bought. They are very lightweight, and I don’t recommend them. A set of Bradco medium duty forks that are much sturdier. Another thing to consider is that longer forks than you need are not helpful, rather clumsy when you’re navigating around equipment and buildings.
/ Pallet fork choice #12
I have express steel forks that I bought about 3yrs ago. I would not want to be removing the forks to use a bail spear or reciever either. The forks are a bit stiff to slide until they wear in and some of the really thick paint comes off. I like them. If I remember correctly they were about $100 more than the cheap chinese crap ones.
No use for a bail spear here but I did weld a reciever onto my loader cross bar. It's always there so nothing extra to put on becids the ball mount.
/ Pallet fork choice #13
I would remove the paint. It will take a long time for it to wear off.
A generous coating of paraffin wax on the mating parts will make adjustments easier.
/ Pallet fork choice #14
I went the cheap eBay route, $300 for a 4000# JDQA fork frame from KOJEM, and another $300 for a pair of 4000# 48" forks from YITA Motor. I've been using them hard for moving logs and pallets for two years now, in fact unloaded a semi truck with them yesterday, and zero problems.
People rail against the quality of Asian products, and often with good reason. But when it comes to something as simple as pallet form frame and fork set, they seem to be capable enough for my needs.
I went with the low frame, no upper guard, because I had plans to possibly add a hydraulic grapple to the frame. In the end, I found the forks worked well enough without the grapple, for my log-moving requirements.
/ Pallet fork choice #16
That's the same concern I have on forks - just how strong is the steel they are made from? Steel varies a lot, and the process of bending and tempering varies even more.
Up until a few years ago there were implement manufacturers that gave buyers a choice between imported or domestic forks @ a difference in price, too. I see that HLA Attachments still does offer both steels for their forks.
Other high implement makers might too... i haven't checked Land Price, Woods, W.R.Long, ALO, Everything Attachments, or Express Steel....and those are just the tip of an iceberg.
Sure wish there was some source listing ALL the North American specialty & implement makers along with some info on each. I'm sure there are a lot of small manufacturers making good products but not much publicity for them.
It could make a good project - maybe a living - for someone. Sort of a tractordata.com for implements.
rScotty
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
40' New Container (A62679)
40' New Container...
