Deutz-fahr error codes
/ Deutz-fahr error codes #1
dim_tsile
Deutz-Fahr 4070E
Hello everyone!
I bought a Deutz-fahr 4070E and suddenly pops up some error codes. Τhe most common code is M358. Some other times its M525 or 521 or the three combined. Sometimes they go away while i'm working and others only if i turn off the tractor. There is nothing like limp mode or something. It works fine while there is a code on the dash. What are these codes indicating;
/ Deutz-fahr error codes #2
M358 speed sensor
Mismatch between Engine RPM and Ground Speed
M521 Range Lever
Signal error from High/Medium/Low selector
M525 Gear lever
Signal error from the 1–5 speed selector
This is what I was able to find for those codes.
Hope it helps.
/ Deutz-fahr error codes #3
M358 speed sensor
M521 Range Lever
M525 Gear lever
Hope it helps.
Would be interesting if they shared a ground connection. I'd look into that.
SHORTWOOD LOG TRAILER (A64276)
SHORTWOOD LOG...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2012 JAYCO PINNACLE ALL-SEASONS 5TH WHEEL CAMPER (A64280)
2012 JAYCO...
2014 Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
2014 Jacobsen...
