Tree pruning in the PNW
/ Tree pruning in the PNW #1
w7dms
Sandy, Ore.
MF1531
Started my yearly job of pruning
/ Tree pruning in the PNW #3
I know the safety police will be all over this one. I personally wouldn't cut off a ladder (no place to run), but, if you were going to do it that set up would make it a lot easier to move from tree to tree.
If you had occasion to have to move a ladder from place to place a lot, that would be something to think about.
Doug in SW IA
/ Tree pruning in the PNW #4
why pruning so high up, visual? i recently cut overhanging branches on a long driveway with an extendable power pole pruner while i was in fel bucket with a dependable tractor operator. not recommended by safety police, but i feel safer than negotiating a chain saw while on ladder, asking for trouble imho.
/ Tree pruning in the PNW #7
agree, i can handle about 12'-14' from ground with mine. on my driveway, i went higher in fel bucket to accommodate dump truck loads.
the power pole pruner is far less expensive to use than ER costs or worse given current escalating health care costs.
/ Tree pruning in the PNW #10
I like your way of thinking!!!
I have a similar tractor/fel/setup. I do crawl up my extended FEL to replace the batteries on my trail cams. I have found that the problem is that since the tractor is off, the FEL shifts downward (loses it's pressure) over time. So there is an about 1" shift of the FEL every 15 minutes or thereabouts. It's unsettling. I have assumed that this is a release to not keep the pressure on the gaskets, etc for an extended period when not in use. If I leave the FEL up off the ground and come back the next day, it is resting on the ground.
/ Tree pruning in the PNW #11
/ Tree pruning in the PNW #12
Our pruning is mostly done. Though I have some wild cherry trees in the lower yard. One is 60' tall below the drain field. I'm going to rig up or buy a rope saw for a few select branches. We'll see how that goes. . .
/ Tree pruning in the PNW #13
What if a cylinder or hose fails while you're up there?
/ Tree pruning in the PNW #16
Cut a couple pieces of pvc pipe to go on the extended cylinders. Lock out supports for working with fel up and having to be under. They'll only drift down that first inch till contact!
/ Tree pruning in the PNW #17
Can say that those rope saws you see on Ebay work! Keep them sharp and an assistant is recommended to avoid it pinching and being hung up.
I changed out the pull ropes with parachute cord. Lighter and way stronger! I was trimming branches 40' up. A lot better than a pole saw. Trying to figure out a way to use with a spring to pull back for solo operation. Anything up to about 20' goes pretty easy, above that is a bit tricky.
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2014 CATERPILLAR D6T XL HI- TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A69167)
2019 FREIGHTLINER...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64557)
2019 Cub Cadet...
2015 SABRE 5TH WHEEL (A67714)
2015 SABRE 5TH...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
