Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions?
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #101
For me, I can put the lift arms at just about ground level and it doesn't make a difference.
And I already make it a bit harder for myself by not keeping the pivot for the blade vertical (to be able to lift it higher), meaning that I have to adjust the tilt of the blade every time I change the angle.
That’s why if you adjust the top link so the cutting edge points to the rear and positioned like a squeegee it will skim over the gravel. It won’t sink in if the cutting edge is angled correctly.
I tried again the other day to shorten the top link as much as possible and it was still digging in to much. Admittedly, the part of the road I was experimenting on is pretty soft though.
Then I tried to reverse the blade (with the pipe still on it) and that stopped all the vibration/chatter I was experiencing when the blade was facing forward.
So I guess the chatter didn't come from the pipe springing back and forth on the mold board like I suspected originally.
With the blade is still reversed, it doesn't solve all my problems, but since the first 5.5" that's in contact with the ground is smooth, that might be enough to let the snow slide down the blade. Maybe. Guess I'll wait until there's snow so I can try it out.
But I'm still pretty stoked anyway as I now know I can "back blade" with the pipe on.
I do that a bit here and there in winter to help smooth out any stutter bumps that start to form on the hills (where the sun melts the snow and drys out the road). Changing to the box blade or LP is too much work just to touch up a few sections here and there. I just make do with what I can accomplish with the blade until the spring.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #103
If the snow is only about 4-5 inches deep, and cooperative, yeah hopefully it'll work. Or at least help.
I have gotten used to having to back up and push the collected snow off to the side every now and then. Life is so much easier when able to run the blade in the correct position when there's solid snow/ice on the driveway.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #104
My gravel driveway is a mile long - right down the section line. I have a 1000 pound Rhino rear blade. Reversed when not hard frozen - straight on when hard as bedrock.
Not had to plow snow since the winter of 2020-2021. Nobody can convince me that we aren't experiencing dramatic changes in the weather.
Ya know oosik, you should have bought those tractor tire chains you were pondering over a while back then it might have snowed some.....
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #105
Nope, it doesn't work that way.
The more equipment and the more prepared I get, the less it snows.
Yep, that's a fundamental law of the universe.
Don't ever buy a recreational toy for the winter. That will really mess things up for years to come. I watched a nature documentary on that a few years back. Apparently, that's how most of the deserts formed.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #107
I'm debating putting the snow chains on the skid steer for this winter.
Last winter I did, and there was no need whatsoever to use the snowblower. Or the blade or plow on the M6040.
Heck, I could've used an RC car with a 4" wide blade to clear the snow we got.
RC car, you say? It better be a gas one, cause I know how you feel about EV's! :ROFLMAO:
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
Chemical Containers Tank (A57148)
Chemical...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
iDrive TDS-2010H...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
