Compact sub compact?
/ Compact sub compact?
Thank you for the update, good to hear the new tractor is earning it's keep this winter. 🍻
I'll say it again that's things like.a invaluable Swiss army knife up here, does a little of everything some things better than others if your mindful of it's limitations.
/ Compact sub compact? #162
It really depends on what you're doing. Case in point: Reversing up steep hills with a loader in 2wd is dangerous, as the rear can become light enough to end up freewheeling down the hill. A 4wd machine can solve this problem, if you actually shift into 4wd, but can still make the machine a bit nose heavy if the load in the bucket is anywhere near capacity for the rear ballast you're running.
Very true, but I'd rather run higher pressure in the front tires than have it wheelie over on it's back. I was running up hill with a 4' 3PT finish mower when it happened and if the raised mower hadn't stopped the wheelie I might not be here. (ROPS was down for cutting under trees)
/ Compact sub compact? #163
As long as you adhere to the max pressure as listed on the tire.
These front tires don’t take much air.
/ Compact sub compact? #164
I don't run max air pressure on any tire ...
On my SCUT TLB the factory tires called for 22 PSI in front, and 20 PSI in the back ... I've since replaced the factory 4 ply rating front tires with 8 ply rated tires which have a max PSI rating of 44 PSI! I run them at 20 PSI ... The rears are at 10 PSI and they don't squat, and are more comfortable to ride on.
My CUT (no loader) calls for 30 PSI on the front, and 20 PSI on the rear, I run 20 PSI up front (thinking of reducing to 15 PSI!) and 10 PSI in the rear, again for ride comfort. (Provides better traction too!)
Most tractor tires, other than turf's are directional ... So going forward will provide the best traction ...
/ Compact sub compact? #165
Most tires are weight rated at their max pressure, so do mind that. My fronts are rated at 30 psi, but the tractor manual recommends something like 18 - 22 psi, based on a lower ply count OEM turf tire. I run them around 20-22 psi for normal daily use, but will air them up to 30 psi when I'm preparing for an special max capacity lift, or when I'm lifting something very heavy higher than usual and want to gaurantee I don't push a bead off a rim in the process.
Follow up on snow removal with my tiny tractor up north. My hacked together 6' utv plow was ok til the snow got deeper I ended up putting the loader bucket back on . Other things I learned the somewhat hard way for next winter the mmm deck will be removed I high centered it on the deck several times in deeper snow. Hopefully it's not damaged to bad but I'm ready with backwoods hackery to get it going. Next year I'm running 4 tire chains, no mower deck, and I'm saving up for a 4' tph PTO snowblower. My neighbor up there has one and cleared the plow bank for my driveway entrance in no time. Before this I was using every inappropriate 4 letter word imaginable directed at the county. I apologize no pics of the snow depth up there but I will say I got a long track deeper lug profile snowmobile buried on my property to the point I had to use a chain fall to get it out, using more inappropriate 4 letter words. This winter was a very decent one up there imo. Maybe I'll post more on my tiny tractor as projects I use it for entail and next winters up grades.
/ Compact sub compact? #168
Six letter words also work if it starts with Mother _____r
/ Compact sub compact? #169
Yes, chains help alot in the snow!
Here is my tiny tractor getting it done ...
I have filled tires, wheel weights and an extra 275 Lbs on the BH frame, to help me keep going straight!
Sure beats a shovel!
Time kill
Next year 4 tire chains, 800 lb tph snow blower off the back for extra weight and the loader will still be attached I'm happy that tractor has enough hydraulic force to lift the front end and curl backwards while I depress the diff lock and reverse it. Got me out of quite a few stupid predicaments I got my self into this winter. I plowed when the snow got deeper with my Yamaha Kodiak 700 with a hacked together weight box hanging off the rear receiver,vbar tire chains, and a ever important windshield ramping snow up the banks til I couldn't. I'm sure next year my tiny tractor with a 6-800 lb snowblower on the tph, 4 tire chains and the loader bucket on front should be a very capable snow removal tool 500 miles from my hobby farm/ inintentional wildlife sanctuary/ home. And I'll definitely find the time to get that tiny tractor ready.for winter up there. Anyways tire chains and weight are game changers when dealing with snow removal tools imo.
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
Unverferth 275 (A64126)
Unverferth 275...
Kubota L2501 (A62177)
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
