adding teeth to a dirt bucket
   / adding teeth to a dirt bucket #1
ironman1952
2023 Kioti RX7320pccb
I have a Kioti RX7320 And I purchased some teeth to weld on to my smooth dirt bucket but then thought maybe I should get all your thoughts on whether it is wiser to just buy a bucket with teeth or perhaps a rock bucket with grapple.
Any thought??? Will welding teeth put the dirt bucket in too much stress? Or???
Regards, Joe
   / adding teeth to a dirt bucket #2
Maybe post pic of your "dirt bucket" to get an idea. are you looking for a tooth bar that can be attached or individually welded? what type of weld/rod? maybe post this in the Welding forum? What's the hp of your tractor? regards
   / adding teeth to a dirt bucket #3
Or maybe dentures. Weld the teeth to a stout bar that you then bolt to the bucket. Take 'em off when you just want to gum the dirt and bolt 'em on when you really want to chew up the dirt.
Eric
   / adding teeth to a dirt bucket #4
What about a toothbar?
   / adding teeth to a dirt bucket #6
Old tractor (NH TC33) had a bolt-on tooth bar that required drilling the sides. In 13 years I've never taken it off.
New tractor (Solis H24) I bought this. Probably never take it off either.
74 hp
I do plan on welding the teeth on to 2 pieces of mild steel as there is a step in my bucket. So I will get the teeth to be tight against the bottom of my bucket and weld them on to the 2 pieces solid. I will then go through the holes that are already drilled into the bucket and bolt them on, so if I ever want to remove them I can.
I have a front end loader that is rated at 3300 lbs so hopefully wont damage them when I attempt to dig'
I know I should have bought a skid steer :-( I have my tractor listed on craigslist and if I can get close to what i am asking I will sell and get a compact track loader.
Honda utv cart (A56859)
Honda utv cart...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
2013 FORD F250 (A60460)
2013 FORD F250...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
