Backhoe B26 backhoe attachment
/ B26 backhoe attachment #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Working slowly on making an attachment that will allow the backhoe to share attachments with the M59 with KX- miniX attachments. Most will probably be too big but hoping the ripper could help with some delicate maintenance. Also there is wide assortment of tools and cheap ears for other tools.
First made a coupler to fit the KX- attachments.
Not a machinist or professional welder. To give the pucks greater strength, inset into holes in the side plates and that doubled the weld area while giving mechanical strength. Rear DOM tube for attachment pin. Great design but does require all six circles to line up properly. If making more than one, a jig to position and weld would be time well spent.
Now to locate, trim and mount the B26 ears. Probably clamp or tack to check operation with machine.
/ B26 backhoe attachment #2
Good work!
I find it frustrating the there isn't an equivalent SSQA standard for backhoe and mini-ex buckets.
The Canadian M59 BH QA ears are even different from the US model. WTF.
Agree.
Frustration with availability of attachments with the M59 lead to KX-miniX conversion.
While the B26 qa with its flared ears is so easy I would vote for the KX-miniX to be standard. Cover 2-18K machines.
/ B26 backhoe attachment #4
Smokeydog,
Looks like you have been busy. Been away from TBN for last couple weeks, clearing son's property and installing fence with tools insufficient for the job.
Do you have any concern with USA's implement weight for the BX hoe?
/ B26 backhoe attachment #5
Nice work. Those fits you got on the pucks are impressive. What was the hardest part of the design? Seems more than strong enough for curling the bucket. I can't quite see what takes the force when extending with the bucket.
Why aren't BH attachments were more universal? Seems like a nice design opportunity for someone.
B26 is the smallest TLB in the series now. BXs are are separate group/series of smaller tractors.
Building a dedicated ripper for the B26 VS this adapter not much added material. KX- ripper not too heavy but maybe too long? Leverage and possible boom strikes a concern.
The 3 OEM buckets I have for the B26 vary only by width. 12” KX- is taller compared to B26 12”. How useful shared attachments other than the ripper?? TBD. Innovative tooling has already improved our abilities to maintain the farm. Just like some SSQA attachments are too big for the B.
Making the KX- coupler portion was much harder than welding the ears. Challenged my limited skills. Heavy weldments with precision alignment with holes and pucks. I would try some fabrication steps differently if a next one. The ears on three different attachments from the same manufacturer vary slightly but all hook up easily.
Mr M59, having an extra mounting pin from the ripper purchase has been most beneficial.
For Kubota to incorporate the KX-miniX QA sharing with the entire TLB line would seem like a good marketing strategy. A proven, popular design with good aftermarket support.
Do like the sexy curved lips Kubota puts on the backhoe and SSQA B-series attachments. Just a little extra metal helps with easy alignment.
Trimmed the ears yesterday. Optimistically sitting them back closer to KX- ear’s attachment points. Tack and evaluate thumb function. Hope the attachment geometry works out.
Sunday funday!
Tacked the ears on for fitment test. Waiting on wife to finish mowing to mount backhoe.
While waiting tried out a new grinding wheel recommended by another poster to sharpen the leading edge of the ripper.
Pferd 61201 5" CC-Grind-Solid 7/8" A.H. - SG for Steel https://a.co/d/fFEgIEN
Cuts quickly and requires little pressure. Reduced 1” AR400 edge to 1/4” in about 20 minutes. Old bones appreciated less strain
Kubota 12” excavator bucket compared to 12” B26 bucket.
Tried test fit, no go. OEM ears interference with thumb. Need to trim front of ears to similar profile as bucket. Typical prototype progress.
Got it on. Thumb has limited range from interference. It is a large ripper for this size of machine. Chewing on how better to move the ears for better geometry?
Third time measuring, guessing, cutting and tack welding got a good fit. Full articulation of the thumb. Easier coupling and better fit overall. Craved a couple pounds off the steel plates.
Better thoughts that this might work. The ripper can hit boom if crowded all in. Working carefully shouldn’t be much of a problem. Sharpened the shank leading edge some more.
Next lay in a couple of good welds and test dig.
Now complete.
Adjusted one ear plate with 0.060” to 0.085” shims to allow hand insertion of pins. Several more tacking and installing checks. Trim sides and fabricate receiver hitch parts.
Welded. Pins fit but are tight. Fitment might loosen some with use. This is where I really appreciate fabrication manufacturers skill of making large weldments. Invest in jigs, weld procedures, go, no-go gauges to make repeatable parts.
Now to paint.
RScotty, The quick attach pins are fully supported and pass through the respective side plates. Sees no rotational force. OEM 1” on the B26 ears and 1.19” on the excavator ears. These see forces at the extreme range of motion with an extension, anti curling movement of the attachment. The pins are not cheap but expect wear or breakage to be rare. The 3” pucks and front pivot point see most of the load.
/ B26 backhoe attachment #13
Congratulations! I remember when you were debating whether to build a dedicated B26 ripper or the adapter.
I think that the M59 could do with a few more backhoe implements - it reall needs a ripper or perhaps a fishtail ripper. I wish that Kubota had made a wider range of OEM attachments to fit.
Your project looks like an awful lot of work. I'm impressed that you did it, although seeing the work involved has made me less tempted to start making an adapter myself.
rScotty
Ready to dig.
Whittling on this blow downed oak root ball.
Good power to break 2-3” roots. Bigger roots take time but tooth and shank do their job.
Ripper 150#, adapter 60#. B26 handles like a champ. Call this a successful venture.
Miss my mega outrigger pads and cylinder guard steps like on the M59. My climbing gear is a little worn and slips sometimes. Just other improvements to look forward to.
/ B26 backhoe attachment #16
This is probably the third time I have read through this thread since it started. It is a very thoughtful and well executed build. I am reading it this time because I am getting a little more serious about building one for the BT1100 backhoe on my L48. It really helps a person to visualize what you want to do with pictures of what others have built.
I have the general idea in my head, but a detail I want to make sure I get right is, the quick change ears. I spoke to a vendor on Marketplace recently about the ears he offers. I noticed he has a couple of different designs, one he says fits the KX40 (and others) and then a different one for the KX57 (and others).
From what I can tell, the KX40 design is the one that would fit the coupler on my BT1100. As I write this post, I am thinking there may be a part number on my bucket that may help me determine which coupler is on my backhoe. I will check into this in the near future.
That thought aside, are there any among us that might have knowledge that could clear this question up for me?
Thank you all,
Doug
/ B26 backhoe attachment #17
Thank you all,
Doug
Doug,
Smokeydog is no longer with us so we have lost a valuable member and his further contributions for B26 and M59. The pictures and posts he has published are all we have for information.
I am not familiar with the BT1100 or the L48 BUT I am fairly certain the ears for the KX40 and the KX57 will not fit the BT1100 quick change adapter as I was frustrated with Kubota's quick change for the M59 as it fit ONLY the Kubota quick change buckets. I finally found USA Attachments and they made a "custom" quick change adapter for me which mates to the M59 and works with the mini ex buckets up to and including the KX40. After I bought one and installed it, I then worked with Smokeydog on the installation details and he then bought one for his M59. He later used the M59 adapter dims and layout and built a mash up so he could use the KX implements ( buckets, ripper, etc) on the B26.
The L48 and M59 both use the identical quick change adapter and TLB quick change buckets. These TLB buckets and KX40 buckets are NOT interchangeable.
The KX57 and larger machines, such as KX80, use a much larger and substantially heavier quick change adapter that is entirely different than used on KX40.
/ B26 backhoe attachment #18
Thank you all,
Doug
Doug, here is a synopsis of an old thread from 2021 in which we are discussing pin ons, QA, and the various buckets. There were several threads. Wish we had all the info in one place.
Here are excerpts from an old 2021 thread in "Kubota Owning/Operating" labeled:
"Backhoe Buckets & Attachments". There were later threads too.
HKBIRDMAN:
I believe Werk-Brau out of Findlay, Ohio makes backhoe buckets for Kubota. My L-47 has the BT1000 backhoe and 24" bucket. I bought it with the K7543 excavator quick connect and it will take any bucket or attachment that fits a Kx040 excavator. I just bought a Werk-Brau 24" ripper tooth and change-over is smooth and it makes pretty quick work of removing 8-10" diameter maple stumps.
JENNIFERKUBOTAM62:
Same here, I was told my M62 quick connect uses the same connection as the mini x's. When I bought mine I bought a Werk-Brau ripper and a couple buckets from the Kubota Excavator line (if you click on the picture you can see the Kubota part numbers).
rSCOTTY:
For the the M62s being sold now, they have one more optional coupler type as an option. So for the M62 you can have the PIN-ON type, or opt for the BT4580 type quick connector for an extra $700, or specify the K7543 type quick connector for an extra $1000. The K7543 is the same quick coupler used on Kubota CE series Excavators. And of course it uses the buckets with the special ears that only fit the K7543 coupler.
The buckets themselves all seem to be identical except for the ears -which are either pin-on, BT4580 style ears, or K7543 style ears...all different, of course. Note that you can order just the ears directly from KUBOTA and weld them onto whatever bucket or QA attachment you want. The ears cost roughly $400 a pair.
I have no idea whether that K7543 will fit onto the M59 or not. It might. Anyone know?
SMOKEY DOG:
My M59 with the BT1200v backhoe has a pin on bucket with a thumb. Studied the parts diagrams on Messicks for QA and think the rear yoke is needed to couple to the QA bucket ears for my machine.
Called Messick’s, Matt in sales about a QA conversion.
The K7543 would fit M59, $1000. That part is good.
BT4580 QA is $750.
Thought I had a winner till I asked if the K7543 would fit my current thumb, and told him the WG price sheet listed separate thumbs for the two QA options. He checked said it looked liked I would need new thumb option too. Additional $2400 for the thumb that fits K7543.
/ B26 backhoe attachment #19
HKBIRDMAN:
JENNIFERKUBOTAM62:
rSCOTTY:
SMOKEY DOG:
BT4580 QA is $750.
Thanks to M59 and rScotty. M59, that is good synopsis.
I have the backhoe off the tractor at the moment, but I was able to see a tag on the back side of the bucket under the quick attach bracket. I am hoping the tag will clear things up with a part number. I am pretty sure it is a Kubota bucket, if what is left of the paint is any indication, as it appears to be the Kubota grey.
I will get back to this thread when I have learned more.
Thanks again,
Doug
/ B26 backhoe attachment #20
Thanks again,
Doug
The weather cleared up enough to get outside for a while. I removed the blade, then mounted the backhoe, so I was able to see the part numbers for the coupler and the bucket.
Coupler-
12" digging Bucket-
It is interesting to note that there appears to be another quick coupler part number- K7770. So, who knows? Maybe this is the quick coupler that works on the BT1100 and nothing else.
Concerning the 12" bucket, I do not understand the two different numbers on the plastic tag. Well, at least one of the numbers is the same as the welded tag, K7872.
Obviously I could have saved a bunch of time staring at a computer screen by just taking the bucket off and recording this information from the beginning. I have not checked the Kubota parts lists yet but will look into that next.
Thanks again all,
Doug
