GrandpaSmurf825
Don't use an air hammer on it. If you swell it in the shaft then you will have to drill it out. It's truly not an issue unless it quits driving the input shaft. Then it's easy to deal with.
Here is something some might disagree with however it's something some manufacturers promote. If the correct shear bolt comes with a self locking nut. When you install it don't tighten it tight. The reason being is a tight bolt will shear easier than a bolt that is "relaxed". I first learned this many years ago on a John Deere 14T baler. The flywheel on the side that keeps the plunger running smoothly that cuts off the hay on the incoming side and compresses it in the chamber used a little 1/4" bolt to drive it. If you put it in and tightened it up tight it would shear again in probably 15 minutes. If you left it loose so you could wiggle it you probably only replaced it every 2 or 3 years. Fast forward to my years as a heavy equipment mechanic. Cylinders on work heads that cycled up and down thousands of times a day rapidly with 1" bolts that secured them. If you ran them loose they would have to be changed because of getting "crankshalved" about once a year. If they were ran tight they would break without warning. That was a mess you wanted to avoid. Broken fittings and oil all over.
Farmer I help. Replaced some flighting in a truck auger. (Auger we load the semi out of the bin with) The bolts that drive the flighting off the gear box have special rubber washer kits to prevent being able to tighten them tight. Because they had failures of the shear bolts related to the bolts being tight. I guess they learned the same thing my father did 60 years ago. Just a lesson I learned that has stayed with me. Tension on a shear bolt makes it more shear easily and that's not always a good thing.
Sorry for writing a book here.
