Sputters when Full trottle applied (Kawasaki 18 HP)(JD)
/ Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #1
topolgwc
Ontario, Canada
John Deere 325
until I really warm the old girl up. When I go full trottle(mower deck engaged), It will reduce revs and sometimes stall. once hot..all ok
/ Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #2
Welcome to TBN
Sounds normal to me.
Richard
/ Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #3
What model of Deere is this motor in?
Is this new problem that developed suddenly?
Does it have a separate choke lever? If yes if you apply a little choke does it run smoother?
325. has developed slowly. when cold it stalls . when fully warmed , she hestitates a little, but goes to full throttle speed.
/ Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #5
Found this on another site:
I have a JD 325 with a 18 hp v-twin engine. Tractor runs great when mower is not engaged. Sometimes when I engage the mower, it will run fine for a few minutes and then all of a sudden it will start losing power/run rough and I will have to slow to a crawl to prevent killing the engine.
I went ahead and ordered an ignition coil
It worked.....thanks a million guys!!! I purchased one of these https://www.ebay.com/itm/114197947568 (Kawasaki part no. 211717034) and before I installed it, I ran the mower until it started running rough. I then turned it off, pulled the right spark plug wire off, turned it back on and it started right up again. I did the same thing with the left spark plug wire and it would not start, so I new it was the right ignition coil that was bad. Replaced it and it runs like a champ! Thanks again guys for all your help!!!
This could be the problem.
THANKS, MUCH APPRECIATED
2015 Ford F-150 Ext. Cab Pickup Truck (A59230)
2015 Ford F-150...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2018 Caterpillar 289D Compact Track Loader Skid Steer (A59228)
2018 Caterpillar...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Autocar...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
