Sputters when Full trottle applied (Kawasaki 18 HP)(JD)
   / Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #1
topolgwc
Ontario, Canada
John Deere 325
until I really warm the old girl up. When I go full trottle(mower deck engaged), It will reduce revs and sometimes stall. once hot..all ok
   / Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #2
Welcome to TBN
Sounds normal to me.
Richard
   / Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #3
What model of Deere is this motor in?
Is this new problem that developed suddenly?
Does it have a separate choke lever? If yes if you apply a little choke does it run smoother?
325. has developed slowly. when cold it stalls . when fully warmed , she hestitates a little, but goes to full throttle speed.
   / Sputters when Full trottle applied (Kawasaki 18 HP)(JD) #5
Found this on another site:
I have a JD 325 with a 18 hp v-twin engine. Tractor runs great when mower is not engaged. Sometimes when I engage the mower, it will run fine for a few minutes and then all of a sudden it will start losing power/run rough and I will have to slow to a crawl to prevent killing the engine.
I went ahead and ordered an ignition coil
It worked.....thanks a million guys!!! I purchased one of these https://www.ebay.com/itm/114197947568 (Kawasaki part no. 211717034) and before I installed it, I ran the mower until it started running rough. I then turned it off, pulled the right spark plug wire off, turned it back on and it started right up again. I did the same thing with the left spark plug wire and it would not start, so I new it was the right ignition coil that was bad. Replaced it and it runs like a champ! Thanks again guys for all your help!!!
This could be the problem.
Giyi 59" Compactor Wheel (A57149)
Giyi 59" Compactor...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A57453)
2016 Ram 4500...
2006 19ft Bayliner USH BOAT w/ 2012 Continental S/A Trailer (A56859)
2006 19ft Bayliner...
(INOP)CATERPILLAR D6R HIGH TRACK CRAWLER DOZER (A58375)
(INOP)CATERPILLAR...
Hydraulic Dingo Brush Hog Attachment (A55272)
Hydraulic Dingo...
2- GARDNER DENVER PUMPS (A58216)
2- GARDNER DENVER...
