need to repair fuel line GC 2310
/ need to repair fuel line GC 2310 #1
DannyLobster
SW Florida
Massey GC 2310 TLB, Gravely 526
I have a leak in my fuel line on my GC2310. It is just before it goes into what I understand to be the injector pump?
It seems a pretty simple fix to take off the hose snip an inch off and replace it. I am concerned about introducing air into the system. I have seen conflicting advice whether bleeding may be required. Any experiences with opening up the system at this point? I assume I should shut of the valve at the filter first, any other advice?
/ need to repair fuel line GC 2310 #2
I've done same to that lower line on gc2400 w/o issues.
It went ahead and it went well with no issues.
/ need to repair fuel line GC 2310 #4
Excellent. I had the same issue in the same spot. I did the same as you did.
I actually bought enough line to redo the whole tractor, but haven’t had any issues since, so the new line hangs on a nail in the garage.
/ need to repair fuel line GC 2310 #5
I still got new lines for pickup pump to fuel tank sitting in shed. did a "temp" repair at pump end(under floor) few years ago and got the new lines planning on replacing them. well...if they split again I am all set :)
/ need to repair fuel line GC 2310 #6
I did the same thing more than 5 or 6 years ago and it lasted for a couple of years before I had to replace it all the way back to the lift pump. No problems with it since, on my 2010 GC2610 at about 1000 hours.
/ need to repair fuel line GC 2310 #7
The line was a lot thinner than I thought it would have been. Way thinner than the line I got from Napa.
/ need to repair fuel line GC 2310 #8
"Way thinner than the line I got from Napa." Not surprising. It seems a lot of the OEM flexible lines on our 2300-series tractors are substantially thinner than replacements.
I'm in the same boat as not2old above -- sounds like exactly the same thing I had to do on my 2310. Tried the "cut off an inch" at first, and that held for a while. Later, I tried to splice in a 2" piece of 1/4" copper tubing (with hose clamps) -- that also held... for a while.
Finally bit the bullet, pulled up the floor, and replaced the whole line back to the small electric pump. No leaks since. (That also gave me a chance to clean out all the crap in there!)
/ need to repair fuel line GC 2310 #9
Had the exact same problem on my 1715, was able to pull up enough to re-attach after cutting split out. Never saw fuel line with seam in it. What size line did you replace it with?
/ need to repair fuel line GC 2310 #10
I haven’t actually replaced the line yet. I just got some in case I ever need it. I think it is 5/16”.
2007 Mercedes Benz -S550 AWD Sedan (A59231)
2007 Mercedes Benz...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2018 Hyundai Robex 35 (A60462)
2018 Hyundai Robex...
2021 Bobcat T770 (A60462)
2021 Bobcat T770...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
