RX7320 Heater Problems
/ RX7320 Heater Problems #1
WarrenLT
Kioti RX7320
I have a 2024 model RX7320. The engine doesn't warm up and the heater doesn't keep the glass clear in below zero weather unless you work the engine harder than just putt-putt snow clearing. Kioti has the heater return going back to the radiator bottom tank rather than the water pump inlet (like everyone else does) which is just like having a thermostat that doesn't close. The engine is getting a steady flow of cold water from the radiator even when the thermostat is closed and it doesn't need it. Has anyone else in winter weather noticed this? Has anyone come up with a fix for this?
/ RX7320 Heater Problems #2
Diesel truckers of yesteryear would place either a zipper curtain over the radiator and manually find the sweet spot for that day's operation by opening it or closeing it. Otherers would use a cardboard cutout with a square opening to limit the amount of very cold air to enter the radiator.
/ RX7320 Heater Problems #3
Or you can get a
very expensive cover to cut down the air flow through the system :)
/ RX7320 Heater Problems #4
Thats weird, i have a kioti dk45 and the heater roasts me out in the winter. I have to crack a window at times.
/ RX7320 Heater Problems #5
Did you check the thermostat to make sure it’s not stuck open? Or opening too soon? It’s a little bit hard to believe that Kioti has it plumbed wrong, do you know of any others of that model with same Issue?
/ RX7320 Heater Problems #6
Bag it like Lou does and check the thermostat in the spring when it's warmer out to work on it.
/ RX7320 Heater Problems #7
Even with a working thermostat I just keep an eye on temps, Even with the front covered up it circulates enough air most days but does warm up the engine a bit faster and the hydraulics seem much happier.
/ RX7320 Heater Problems #8
I haven't seen a specific fix for the RX7320 yet, but you might be able to reroute that heater hose to the water pump inlet instead. Does anyone know if moving that hose works or if there is a kit for this?
/ RX7320 Heater Problems #9
I have covers I made for where the screens go in front of the radiator. Pull the screens and slip in the pieces. I have only used them once but worked very well and had no problem having enough heat. As far as windows fogging up, I leave on the A/C to suck out the moisture and it keeps the windows clear.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
NorTrac Rake (A64127)
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
