Ryobi Gas Powered Sawzall
/ Ryobi Gas Powered Sawzall #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
I found a brand new Ryobi gas Sawzall 5 miles from me.
“Brand New, Has never had gas in it” they said.
Asking price $275.
I explained the issue that parts are no longer available, it’s 25+ years old and although never used, it may not run.
I offered $200 and they accepted. Even has the allen key blade change tool and the lanyard for it.
Told them I might be able to get it today.
/ Ryobi Gas Powered Sawzall #3
I'm assuming this is a prank as I've never seen such a thing. Although we did have gas powered drills when I was doing arboriculture work almost 40 years ago. With today's battery tools, I can't imagine why someone would want a gas-powered tool of such, other than as a curio.
/ Ryobi Gas Powered Sawzall #4
MIn thing needed would be fuel lines! When you get it, post what engine make is on it. Could be something that has parts available, just not through Ryobi.
/ Ryobi Gas Powered Sawzall #5
I think Tanaka makes a lot of these small gas engines.
Oh no, it’s 100% real.
I already have the Ryobi gas hammer drill.
It runs, drills and hammers quite well.
They built a recip saw, a hammer drill, and one other gas powered tool, I believe.
/ Ryobi Gas Powered Sawzall #7
Saw that on FBM in Wilmington. Some tools come and go without becoming well known. Back in 1970 I worked for a small contractor who bought an Atlas Copco gas-powered jackhammer. They're still in business but I've never seen another one being used.
/ Ryobi Gas Powered Sawzall #8
I have the same model Ryobi gas recip saw that I bought in the late 1980s, I think, from a close-out tool catalog.
Used it around the barn to make some repairs to the rough oak framing because didn't have any power at the barn and didn't own a generator at the time. Back then, there weren't that many cordless recip saws to choose from.
What I remember is that it worked, but was fairly heavy compared to any electric recip saw. Still have mine in the original box.
/ Ryobi Gas Powered Sawzall #10
While you could put any length recip blade you want on it, I don't remember mine being a particularly fast cutting saw, at least through full dimension oak sawmill lumber.
I just went down the road, picked it up and while I was at sellers house, I unscrewed gas cab.
This saw is brand new. Never even had fuel in it. Mint condition. Same as new.
I gave him $200 and headed home.
Fueled it up and I was shocked that it started in 5-6 pulls and runs very well. Like zero smoke for a 2-cycle.
Now I have the drill and the saw.
/ Ryobi Gas Powered Sawzall #12
so parts are hard to get....is the blade mount universal?
There are no spare parts-at least not to my knowledge. Ryobi stopped making them like 25+ years ago. You can’t even get an air filter for them.
If you really want to use one hard, better have a “parts” machine in case your “runner” takes a dump.
I use the hammer drill here and there, but the recip saw….well….let’s just say this one I will have to find a use for. 😁
/ Ryobi Gas Powered Sawzall #14
will conventional replacement blades mount? if so, you got a good one
Yes! I was kind of sweating that, too. The blade end looks just like a modern sawzall blade end.
However, it has an allen-key style removal tool, so it’s not “tool-less”. It does have a tethered allen key, so at least it shouldn’t get lost. You can see it just forward of the fuel tank on its’ tether.
/ Ryobi Gas Powered Sawzall #16
like it. assume your fuel is always ethanol free. carb parts could be a tough one, but if it works, sounds like it's a go.
leaving it stored w/dry tank can also pose carb problems vs leaving fuel for long storage of non use if properly treated, regards
I think it has a Walbro carb.
It sat without fuel for over 25 years. I fueled it for the first time today ever, and it started in 6 pulls. That blew my mind.
/ Ryobi Gas Powered Sawzall #18
Neat tool. I have a Skidril post pounder tool. It's also gas powered and will drive up to 3" pipe. It's been flawless to date, but I always run premium Stihl 2-cycle and I'm meticulous on the layup.
/ Ryobi Gas Powered Sawzall #19
Many years ago we had a gas powered drill with a 5 or 6 foot extension boom. We used it to drill holes for running wires thru ceiling joist. No ladder needed. But sure could smoke out a jobsite.
Other trades not happy while we worked
My Ryobi Drill smokes a little, but this sawzall doesn’t.
These things run on 20:1 ~ 25:1 according to the cap, or the carb cover
