2018 RAM vent
/ 2018 RAM vent #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I purchased a 2018 RAM 2500 truck brand new in 2018. However, for the past year, it has been considered unsafe to drive due to a faulty hydraulic brake control module. This issue is currently under recall, and despite having only 14,000 miles on it, it has become a useless driveway ornament.
RAM’s response is that they have no repair options but are “working on” a solution. I’ve made numerous attempts to get a repair or some real assistance from Customer Service, but it’s been a frustrating cycle of being transferred between departments without any useful solution. The only option is to rent a cheap car, and if I meet all their requirements, they might reimburse me. However, that’s a lot of hassle, and I bought a ¾ ton truck for a reason—to tow and haul. A car or tiny SUV which falls in their rental policy is a useless substitute.
It’s extremely disappointing that RAM doesn’t care enough to solve this issue promptly or offer a real solution. I’ve learned a valuable lesson: I’ll never buy another RAM product. I hope you learn from my experience.
/ 2018 RAM vent #2
With todays tech it’s becoming more of a problem… it took several years for my airbag replacement and I was advised not to drive the vehicle until repaired…
Disappointing to say the least…
/ 2018 RAM vent #3
@Code54 Ouch! That has to be beyond annoying. I've had minor variations of that in the past, but nothing that bad. I was out of one car for four months while the shop that wrecked it argued with my insurer over who was going to pay to get me a working car. I commuted from a remote area at the time with no alternative transport besides a bike. An extra two hours a day by bike (big hill).
Good luck on getting a fix from RAM soon!
All the best, Peter
/ 2018 RAM vent
It truly irks me to no end. I understand that things happen, but by the time it was recalled, they had already been aware of the problem for quite some time. They have a solution for several other years, and even the 2018 3500, come on guys, get it done.
/ 2018 RAM vent #5
It's not just a Ram problem. The supply chains started to crumble in February 2020, and we are still reeling. Unfortunately, your situation is not uncommon or unique. I supply machined parts to the big aerospace companies. We are years late on projects because of severe material shortages (castings).
/ 2018 RAM vent #6
No, its not. All three of the HD truck manufacturers are having supplier problems...but Ram seems to be the worse.
I own two HD Rams so I'm on the Ram forums all the times and lately the number of complaints with the newest Rams have grown exponentially. For one, after many many years of having Cummins engines built with solid lifters for some silly reason they are now made with hydraulic lifters and these new engines seem to be having teething problems. And the problems with electronics are myriad. The latest - apparently there is some kind of sensor on the rear axle that goes bad. When it goes out the transmission will refuse to go into Park position. And if the transmission can't go into Park, the engine cannot be shut off. Owners are having to pull the battery cables off the batteries to shut the trucks down. And they are being told that those sensors are on backorder - with a 4 month leadtime!
Reading about all the problems makes me so happy I own older Rams. They've been essentially trouble free.
/ 2018 RAM vent #7
It’s crazy just how much we rely on electronic controls…
I don’t see it getting any better so more to come.
There are work arounds but if you are purchasing new hopefully it happens during a warranty for two reasons…
Statutes extend warranty for periods the item is out of use due to a warranted issue.
Second… defects that affect either the use, value or safety can be the basis for a Lemon Law buy back…
Some are Federal and some are State statutes.
I’ve seen many otherwise good running vehicles junked for failure to pass emission test… either too expensive to repair or parts not available… especially in a state that still tests back to year model 1976.
/ 2018 RAM vent #8
The Ram dealer put a brake module in mine under the recall. They made an appointment for the next week after I took my truck in and they swapped it in 3-4 hours.
/ 2018 RAM vent #9
I have an 07 Ram and was considering a new purchase until I joined a Ram forum and begin to read about all the issues with new trucks sitting at the dealer with no repair parts to be had, while the customer has to rent something and still make payments on a truck that isn't usable!! Not to mention all the lifter / push rod failures and the intake grid heater bolt falling off and destroying the engine. And we're talking about 100K trucks !!!
I think I'll just keep my 07 5.9 for a while longer
/ 2018 RAM vent #10
It’s not just Ram. I own a F150, they have their share of problems. I have a friend that had a AFM problem on his Chevy, over $5k to fix. The bad part is you are left hanging. I’d do some research and see how “unsafe” it is to keep driving it. Is Ram just being extra safe or is there a real risk to keep driving it?
/ 2018 RAM vent #11
That creates a large vacuum (sucks). GM does the same with recalls, sends out the notice but it states don't take it to the dealer, wait till we notify you we have a solution. Not a safety issue but GM has supply problems as well. The heated steering wheel switch went out on my wife's 2025 Tahoe. They have to replace the whole steering wheel. It is back ordered with no date available. Guess they got a bad batch at the factory and lots of folks are having issues.
/ 2018 RAM vent #12
Sorry if I missed it, but what is the issue with the 2018 Ram 2500? Does it need a replacement module or parts that are not available?
/ 2018 RAM vent #13
I have a 2018 Ram 2500 with the same brake problem, its in the bosch pump (they fail).
So when you're driving down the road all you hear is ding ding ding reminding you. I still drive mine everywhere and the brakes still work.
I even towed a trailer and they work, but the noise is a drag. I only have 28,000 miles on the truck.
They also want me to take it in so they can reprogram the computer so that is uses more DEF fluid, I told them to take a hike.
That recall is a 67A update
/ 2018 RAM vent #14
Another case of the consumers getting screwed over. There should be laws to protect us from this donkey dust ! They should have to provide you an equivalent vehicle until their problem is fixed. If it was me, I would continue to drive it until they can fix the problem.
/ 2018 RAM vent
It is just a 2018 2500 issue now from what they are saying. It seems they have the other years and models fixed.
I would be happy if they would fix it, but until then, just get me an equivalent vehicle to use. I am really only asking for exactly what I paid for, nothing more.
/ 2018 RAM vent #17
Geez that has to be great for the diode pack and voltage regulator in the alternator as well. I agree, Come on RAM Get Your S together.
We like our older RAMs but they have their own issues like the TIPM , cracking dashes, stuck power seat regulators, recalled air bag inflators and somewhat cheap and air vent actuators that break, but agree the main things, engine -drivetrain are solid.
/ 2018 RAM vent #18
Not available at any junk yard?
Somebody must have crashed an '18 by now, and as long as the crash wasn't because of a bad brake control module it could be a good part.
/ 2018 RAM vent #19
The only sense I can make of an electronic brake control module is that it controls the anti-skid/spin function? If true this should NOT affect being able to drive the pickup?
If one is told to NOT drive the rig it seems to me that it in place because the lawyers said it had to be stated that way. This way there isn't a new commercial by law firms asking if your brakes failed to call their hot line.
/ 2018 RAM vent #20
Is there no way to just kill the dinger?
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2012 John Deere 6430 (A64911)
2012 John Deere...
Mower King QA Brush Cutter (A64912)
Mower King QA...
CATERPILLAR C1.5 LITER (CONDITION UNKNOWN) (A68842)
CATERPILLAR C1.5...
2014 HIPOWER 310 GENER (A67714)
2014 HIPOWER 310...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
