What is this part and function?
/ What is this part and function? #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
Kubota 3410 HST. I am replacing my rear tires. I took them off to take to tire dealer to have the new ones mounted. While they were off, I cleaned things up a bit and this part (see photo) caught my attention. I could not tell what it did, and the very intentional-looking lever-like device with teeth did not seem to relate to any other part. However, it also seemed bent outward a bit and that may be why I cannot see what it is to connect to or function with. I played around with other functional levers on the deck to see if anything moved there, but none seem to affect this part. I will pick up the new tires in a day or two but before I remount the new tires, I thought I should learn something about this part - given that it may be bent.
Any help will be greatly appreciated. I am prepared to be embarrassed by something I should know but do not. And BTW, I also found a couple of missing bolts on another part that I would not have easily seen with the tires on.
/ What is this part and function? #2
It does look bent ;-)
I have no idea "what it is", have you tried moving it and seeing what wiggles elsewhere?
Interesting that TWO cables are part of a position loking lever/
CalG, I can't move it by hand - it is very firm/stiff. I did try moving some of the functional levers on the tractor deck to see if any of that would affect this part but I did not see that any that I tried did. I have the original manual but nothing there shows or addresses this. I am thinking that the part with teeth needs to be been in- or repositioned inward - in which case it could connect to another part in front of it. I am alone now so hard to view this part while trying out other levers, etc. but tomorrow I may be able to have someone help with that.
My first thought would be the locking mechanism for the parking brake.
My thought as well, as it would seem it could be - and would need to be 'released' as a brake would be, but moving the brake does not seem to affect it - but I really need another person here to really check that out. Will try that tomorrow if I can round up someone else.
It's the cruise control.
Aha! - RJ, Thank you - the diagram you have provided is precisely what I see. And I guess a reason why I did not know and could not figure it out is that I have never, ever used the cruise control on the tractor.
/ What is this part and function? #8
That's sure a puzzler beowolf! Sorry but I have no idea what it might be for? Like Randy I first thought of brake lock, but it's spread too far apart for that. Hope you can get it figured out!
/ What is this part and function? #9
I thought I would use the cruise control on my last 2 tractors... But no. First one (coincidentally an L3410) was manual and I never used it. My current L4060 has electronic cruise control, and I thought I would use it.... But no.
/ What is this part and function? #10
This came in just as I posted and it's most likely right! I've got cruise on my tractor but have only used it to try it out! Good diagnosis RJ!!
/ What is this part and function? #11
Both of my tractors have (unused) cruise control and the other day I DID use it on the old Ford while using it to blow leaves. This was the first time in about 20 or 25 years and only for about 10 minutes.
Don't call the safety police, but the last time I used it was when mowing under trees on a neighbor's yard. I wouldn't do it again today. I'm a little more careful now - and at 76 not quite as nimble:)
/ What is this part and function? #12
In the old days with gear tractors, you set the engine speed, pick a gear and that was your cruise control.
That is what they were trying to emulate. Lets you do anything you want with your feet. With the old tractors you could even stand up over a rough section of ground, allowing your legs to become suspension so your body didn't have to take the shaking. These days the switch under the seat kills the tractor, if it becomes unloaded.
/ What is this part and function? #13
Knew a guy years ago that had a Ford tractor that would pop the tranny into neutral if you stood up off of the seat. Guy discovered it while going down a hill, and stood up to get better visibility. You know the rest..
/ What is this part and function? #14
/ What is this part and function? #15
I use the manual cruise control on my Kubota L5030 HSTC probably 90% of the time!
Of course I use it mostly for just mowing, and if I need to slow down or speed up, I just reach down and adjust the lever ... So far .. I don't really like the "treadle pedal"!
That is it in a nutshell. Wide open areas where you want to go the same speed and direction is where constant speed is nice and a geared tractor is just fine. Let out on the clutch once, until you are done.
Start doing lots of repetitive back and forth actions, like loading, stacking hay and such, the pedal starts to feel a lot better than a clutch and the cruise lever doesn't get touched.
/ What is this part and function? #16
I don't do constant speed with my HST and cruise control, I have a lever beside my left thigh ... I just move it forward or back to adjust my speed or stop, doesn't work in reverse, but basically lets me avoid using the treadle pedal, it's a forward hand control ...
/ What is this part and function? #17
That lever is the "cruise control" lever.
/ What is this part and function? #18
Yeah, I know all that, I actually have two of the manuals, whan I bought the tractor I didn't know that there was a pouch behind the seat, and that the original manual was in it, so I ordered one, and read it, and found out about the pouch behind the seat (not really noticeable in the cab unless you know what your looking for) ...
Note it says to "move the lever", (that means by hand) and I'm not "disengaging" it at that time anyways ... And "preferably" (means optional) ...
Have ever owned or operated one of these?
My Massey Ferguson GC 1725 MB is much different and not really adjustable "on the fly" like this Kubota is.
/ What is this part and function? #20
There are two cables. If cable #90 is the cruise control cable, what is #10?
Also, the angled bar with the notches isn't numbered. What is it for?
It appears to me that cable #10 sets the cruise control and cable #90 is the brake release. The notched bracket holds the setting, don't know why it's not labeled.
2011 FORD F-150 (A65643)
2011 FORD F-150...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
