What is this part and function?
   / What is this part and function? #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
Kubota 3410 HST. I am replacing my rear tires. I took them off to take to tire dealer to have the new ones mounted. While they were off, I cleaned things up a bit and this part (see photo) caught my attention. I could not tell what it did, and the very intentional-looking lever-like device with teeth did not seem to relate to any other part. However, it also seemed bent outward a bit and that may be why I cannot see what it is to connect to or function with. I played around with other functional levers on the deck to see if anything moved there, but none seem to affect this part. I will pick up the new tires in a day or two but before I remount the new tires, I thought I should learn something about this part - given that it may be bent.
Any help will be greatly appreciated. I am prepared to be embarrassed by something I should know but do not. And BTW, I also found a couple of missing bolts on another part that I would not have easily seen with the tires on.
   / What is this part and function? #2
It does look bent ;-)
I have no idea "what it is", have you tried moving it and seeing what wiggles elsewhere?
Interesting that TWO cables are part of a position loking lever/
CalG, I can't move it by hand - it is very firm/stiff. I did try moving some of the functional levers on the tractor deck to see if any of that would affect this part but I did not see that any that I tried did. I have the original manual but nothing there shows or addresses this. I am thinking that the part with teeth needs to be been in- or repositioned inward - in which case it could connect to another part in front of it. I am alone now so hard to view this part while trying out other levers, etc. but tomorrow I may be able to have someone help with that.
My first thought would be the locking mechanism for the parking brake.
My thought as well, as it would seem it could be - and would need to be 'released' as a brake would be, but moving the brake does not seem to affect it - but I really need another person here to really check that out. Will try that tomorrow if I can round up someone else.
It's the cruise control.
Aha! - RJ, Thank you - the diagram you have provided is precisely what I see. And I guess a reason why I did not know and could not figure it out is that I have never, ever used the cruise control on the tractor.
   / What is this part and function? #8
That's sure a puzzler beowolf! Sorry but I have no idea what it might be for? Like Randy I first thought of brake lock, but it's spread too far apart for that. Hope you can get it figured out!
   / What is this part and function? #9
I thought I would use the cruise control on my last 2 tractors... But no. First one (coincidentally an L3410) was manual and I never used it. My current L4060 has electronic cruise control, and I thought I would use it.... But no.
   / What is this part and function? #10
This came in just as I posted and it's most likely right! I've got cruise on my tractor but have only used it to try it out! Good diagnosis RJ!!
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
