Rear weighting device
/ Rear weighting device
Nice pile of hand made weights. When I saw it I was thinking something like those rectangles from a weight machine.
Then... jumped a bit. Perhaps if one had a 2" round bar one could load it up with 20kg or 45lb cast iron free weight discs if one could find them cheap.
I'm not young for sports anymore 🤣
/ Rear weighting device #23
This is how it's done! The first three or four piles are driven using an excavator attachment.
I'm not actually sure how they do it now. 40 years ago when they first started, it was all done with a vibratory attachment suspended by a crane, and powered by a standalone engine/hydraulic pump. Some of these sheets are 40' long/tall. It would take a very large excavator to handle those.
/ Rear weighting device #24
A 3/4" black iron pipe is basically 1" ... That's what I used, and it just happens to slide through my BH frame mounts, the biggest weight plates I use are 25 Lbs, with a 1" center ...
Of course you could go with a bigger pipe if you wanted to use the QH to hold it, but my main purpose for this is with a rear blade, that when being used, all that weight is on the ground, I needed more TRACTION!
/ Rear weighting device #25
Yes, well, you were using your baby tractor to do a job it was never intended to do. Of course, you have always found a way to do lots with little.
But a word of warning: never share your TBN profile with a potential buyer of that baby if you ever decide to sell it 🤣😂🤣
/ Rear weighting device #27
Interesting.
Here in the USA I believe it's called "sheathing" or "sheeting". One of my brother-in-laws used to be in the gasoline pump and tank installation business, and ended up using this on his sites. Today, ALL he does is install and remove the sheets for other contractors.
I have only known it as sheet pile here in the PNW. It's nice to learn a new name for it and a little bit of history about it also.
/ Rear weighting device #28
During the winter snow removal, the front loader was overbalanced and the rear wheels were slipping. I welded a basket for the rear hitch and placed 20-millimeter plates cut from Larsen tongue into it. The work became more enjoyable.
I just put a heavy duty 9 foot blade on the back of my oliver 1800. Got chains I should use . But at 120 lbs a real chore to put on by myself !!
/ Rear weighting device #29
Larsen's tongue is a special metal profile with locks that is driven into the ground and connected into a solid wall. The technology was developed in the early 20th century by the German engineer Larsen.
Features:
Visually resembles a trough with rounded side edges, which are the locks.
Due to the locks, the products can be connected into a single tongue wall.
I cut the plates from the part outlined in red. Ordinary 3-grade metal
Very interesting
I am too lazy to cut out the flat parts. Seeing as the stuff nests well, I would have made a bigger box to hold the sections
/ Rear weighting device #30
See you are from Russia so a special welcome to you. I got to know a Russian on a shooting forum and we have communicated a bit since the war with Ukraine and the sanctions. He lives not far from Moscow.
It was interesting to get the perspective of a normal man about the situation.
One thing that politicians and media ignore is that people are people and we have much in common.
Again, welcome.
I use a manual wheeled garage crane to attach heavy equipment, which makes things much easier.
Very interesting
The weight of each plate is about 10 kilograms (22 pounds). This weight makes it easy to unload the plates.
Again, welcome.
Thank you ! I am a direct participant in these events. But we are here to discuss tractors and their equipment. Peace to all )
/ Rear weighting device #34
Nice Build!
I find the trick to adding rear ballast is to use something that does more than just add weight. Usually, it's an implement. In winter, I leave the spreader attached. It weighs 2800# loaded with anti skid. It articulates, so I can always dump some if I need less weight.
In summer, I leave a 3pt mower or the backhoe attached.
/ Rear weighting device #35
They used a diesel hammer to drive sheet piling. The diesel hammer operated by a heavy weight that would be released from the top and as it drove downward it built compression and fired. It would drive itself back up and then fall back down, fire and begin all over. It would hammer until a compression lever/rope was activated to relieve compression, as well as a fuel shut-off valve.
On bigger jobs we used a vibratory table. Diesel powered engine built on a table that attached to a crane. It had a hydraulic vibrator attached that had roller bearings, BIG, that would be attached to the material being driven. It was something to see and feel as the ground would shake around it! We used it to vibrate big casings into the ground for drill shafts. It was something to see.
/ Rear weighting device #37
They don't make wheel weights anymore??
/ Rear weighting device #38
I’m still new to the sport of tractoring, however, from what I read there is a difference between weight in/on your rear wheels and counterbalance weight hanging out behind a tractor… each has their place but neither replaces the other…
Then again… I could be wrong…😳
/ Rear weighting device #39
Wheel weights were not quite enough...... Dead Deere is 520 LBS, counter weight about 600 pounds....
/ Rear weighting device #40
For the OP's situation ... Either rear ballast weight or rear wheel weights would work for his lack of traction problem he was trying to solve ...
If a QH is used, the rear ballast is easier to take off or put on quickly as needed ...
I leave my steel wheel weights on all the time, they do not help with relieving the front axle of overloading the front axle by heavy loader work ...
This chart taken from the following video at about 7:20 into it, explains why the previous post worked with rear ballast, but not wheel weights (presumably liquid?) ...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
6' SCRAPE BLADE W/ SLIDE, 3PT (A64278)
6' SCRAPE BLADE W/...
3144 (A63117)
3144 (A63117)
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
