Row hipper
/ Row hipper #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Is that the correct terminology used to describe this?
I’m not seeing any videos showing the single disk like this has?
Maybe it’s incomplete?
I’d like to understand better how it’s used
Are there different sized disks ( I believe there are ) and how does that affect the end result.
I understand that this is a toy to many of you guys with bigger tractors.
It is original equipment for my older tractor and I do believe it can be made to work on this smaller scale gardening.
Thanks
EDIT: I will post better pictures tomm if need be
/ Row hipper #2
I understand that this is a toy too many of you guys with bigger tractors.
It is original equipment for my older tractor and I do believe it can be made to work on a smaller scale
Thanks
Hi 1930, I've got something like this last photo. It's used for making rounded/piled/rows for planting crops in. Potatoes, corn, etc., etc. I forget exactly what it's called but I think its called a hiller.
On mine you can adjust the width of the harrows by sliding them closer together or farther apart. Gives you a fatter or narrower row.
It's used in areas that have been thoroughly worked up already and the ground is soft for shaping. I used mine after tilling well. I haven't used mine in quite a few years though. We quit with the large garden - was just so much work to tend. Now that I'm retired I may get back into it though!
You've got the right equipment on hand to do a good garden though. Just plug away and you'll figure it all out!!
Good luck, Greg
/ Row hipper #3
We call it a hiller. As Gregster mentioned it's good for hilling potatoes. By moving the discs closer together you can use them on corn.
Wider apart -about where they are now- they make good raised beds for seeding beds and planting deep rooted vegetables like carrots amd beets. If you're clever you can modify them to make raised beds, lay plastic and bury the edges all at the same time.
I'm not clever.
/ Row hipper #5
Others are correct but I will add; there May be additonal tools that attach to that tool bar other than the hilling disc's. You may be able to get S sweeps that attach with a collar to that bar, as well as other impliments. Here is a row opener and a middle buster that can attach to a similar tool bar as you have
/ Row hipper #6
Others are correct but I will add; there May be additonal tools that attach to that tool bar other than the hilling disc's. You may be able to get S sweeps that attach with a collar to that bar, as well as other impliments. Here is a row opener and a middle buster that can attach to a similar tool bar as you haveView attachment 4356430View attachment 4356431
You're quite right Paulsharvey, I didn't mention them but they are available. I've got the middle-buster as a separate implement and have used it also for quite a few various tasks I've done.
I thought he was only asking about what he showed as already owning. We TBnrs often spend others money for them! There are "a lot" of other items he "could" buy to make his tasks much easier, but that's his choice!
/ Row hipper #7
Hillers are often used in conjunction with Danish sweeps or similar, as the hillers won't move much soil if its at all compacted
/ Row hipper #8
Thanks
Here's a decent video about it --->
2018 Ford F-250 Ext. Cab Pickup Truck (A66736)
2018 Ford F-250...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
