/ Ck2610 Backhoe Pin wear #1
KiotiDKR
Newfoundland
Kioti ck2610
400 hrs on this tractor and experiencing (IMO) a lot of pin wear on backhoe especially the shoulder pin( bottom one ) . Not a lot of backhoe use ( maybe 15hrs ) but a lot of traveling moving fill with bucket . I leave Hoe on for counter weight . With all the travelling the Hoe is moving around a lot and i think it’s causing wear and definitely alot of noise . I have secured the hoe and out riggers with Ratchet Straps to keep from moving .. I think this will help with pin wear .. also secured Backhoe seat with rubber strap to keep noise down ..
/ Ck2610 Backhoe Pin wear #2
That's a new issue I have yet to see.
My hoe is on by tractor 100% of the time, and 20y + 1200 hours have not had this happen. My hoe is a Woods copy, with maybe 200h on it. Love the ballast, which allows me to lift a ton with the loader.
When you say, "travel", do you mean at top speed, like 15MPH or more?
Yeah as fast as it will go lol .. I have been moving a lot of fill .. about 30 tandem loads about 250 meters return trip .. and the route is very rough.. a lot of banging around..again this is just my opinion and the straps have definitely quieted everything down and now very little movement in the backhoe ..
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2002 48ft. T/A Flatbed Trailer (A61573)
2002 48ft. T/A...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
