What battery charger do you use?
/ What battery charger do you use? #21
UPDATE: I recently ordered a Schumacher SC1280 4-in-1 charger that is supposed to be compatible with AGM or FLA batteries. It also has desulfation/maintenance/3A & 15A charging. Should be here soon. Will post results! Incidentally: I have a Schumacher SC-600A charger that I hooked up to an old AGM Excel battery. It reached "fully charged" status in less than 15 minutes, at 2 amps!
/ What battery charger do you use? #24
/ What battery charger do you use? #25
Im posing to say that agm feature will pay off in longevity. It shortens the life to charge them improperly although it not apparent. It really matters on a four wheeler or lawnmower battery. I like agms but they do require a little special treatment. Keep us posted on your new fancy charger
/ What battery charger do you use? #26
Never had one so far, but I'm only 76 so maybe one day.................
If a good battery is discharging, fix the problem. If the battery is bad, replace it.
I have a very robust set of jumpers for when "do-do" happens. Recently the battery in the L4240 gave up. Trailblazer rescued it from outside the shed even though the tractor was nose-in.
/ What battery charger do you use? #27
Both of my chargers are older. I have a Die Hard (Schumacher) 2/10/50 auto charger with a setting for agm. The other is a wheeled Schumacher 2/10/40/200 that will also do 6v. For maintainers, I have 3 wall wart Battery Minders.
/ What battery charger do you use? #28
I have an old charger I haven't used for charging in 20 years but keep it because it has a "start the motor" feature. Don't ,see this on modern chargers unless you want something commercial in size and price.
/ What battery charger do you use? #30
So true chim. Sounds like you charge them on the go! I mostly charge something when I let it set still to long. I guess I’m guilty of having to many toys. But I’m as you are, in my seventies. Still enjoying it!
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
