What battery charger do you use?
   / What battery charger do you use? #21
UPDATE: I recently ordered a Schumacher SC1280 4-in-1 charger that is supposed to be compatible with AGM or FLA batteries. It also has desulfation/maintenance/3A & 15A charging. Should be here soon. Will post results! Incidentally: I have a Schumacher SC-600A charger that I hooked up to an old AGM Excel battery. It reached "fully charged" status in less than 15 minutes, at 2 amps!
   / What battery charger do you use? #24
   / What battery charger do you use? #25
Im posing to say that agm feature will pay off in longevity. It shortens the life to charge them improperly although it not apparent. It really matters on a four wheeler or lawnmower battery. I like agms but they do require a little special treatment. Keep us posted on your new fancy charger
   / What battery charger do you use? #26
Never had one so far, but I'm only 76 so maybe one day.................
If a good battery is discharging, fix the problem. If the battery is bad, replace it.
I have a very robust set of jumpers for when "do-do" happens. Recently the battery in the L4240 gave up. Trailblazer rescued it from outside the shed even though the tractor was nose-in.
   / What battery charger do you use? #27
Both of my chargers are older. I have a Die Hard (Schumacher) 2/10/50 auto charger with a setting for agm. The other is a wheeled Schumacher 2/10/40/200 that will also do 6v. For maintainers, I have 3 wall wart Battery Minders.
   / What battery charger do you use? #28
I have an old charger I haven't used for charging in 20 years but keep it because it has a "start the motor" feature. Don't ,see this on modern chargers unless you want something commercial in size and price.
   / What battery charger do you use? #30
So true chim. Sounds like you charge them on the go! I mostly charge something when I let it set still to long. I guess I’m guilty of having to many toys. But I’m as you are, in my seventies. Still enjoying it!
AG-FAB PULL TYPE SWEEPER (A58374)
AG-FAB PULL TYPE...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
1449 (A57192)
1449 (A57192)
2020 DRAGON ESP...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
