Anyone DIY dye their hydro oil?
/ Anyone DIY dye their hydro oil? #1
WinterDeere
Super Star Member
Rural 'burbs, north of Philly
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
/ Anyone DIY dye their hydro oil? #3
I use the JD dye. It works, turns the oil red. Does not take much. My L3600 has a sight glass, could not see the oil without the dye. Easy, just pour it in. Might mix with some of the oil to pour easier.
/ Anyone DIY dye their hydro oil? #4
Did you get that local or order it online? I have been wanting to add some to my tractors.
My tractor has a dipstick, so I don't need to dye mine.
I've read here on TBN that John Deere sells a dye specifically for hydraulic systems.
Mine has a dipstick, too! But both sides are cross-hatched, there's no smooth side for viewing the "wetted" line. Just about impossible to see the fluid without walking out to daylight with the dipstick in-hand.
/ Anyone DIY dye their hydro oil? #6
I ordered mine online, but you can find it locally also. I used more than was needed also - just use use a tad bit of it and it works fine.
/ Anyone DIY dye their hydro oil? #8
I got it online from a tractor store. It was silly expensive on Amazon. Little bit goes a long way. My Kubota has the impossible sight glass. It must be a Japanese thing. My Yamaha has one too :rolleyes:
/ Anyone DIY dye their hydro oil? #9
JD sells it, it's expensive per ml, you might get 2 fills out of it but they suggest it's for 5 gallons (if it's pasty or dried up, add hydraulic fluid and stir!) ... I bought mine from https://www.zoro.com/kingscote-dye-...red-4-oz-506250-r4/i/G5130815/#specifications (I bought some gloves also to bump total up to get "free shipping!")
Wear gloves, I recommend pouring/dripping it into the jug, then pouring into tractor ...
2 drops per gallon ...
204158 (A57193)
204158 (A57193)
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A61165)
1999 Van Hool...
Vertical Steel Well Tank (A61570)
Vertical Steel...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2024 Linx EQ07020RS (A60463)
2024 Linx...
John Deere Hopper Assembly Kit (A60463)
John Deere Hopper...
