Anyone DIY dye their hydro oil?
   / Anyone DIY dye their hydro oil? #1
WinterDeere
Super Star Member
Top Poster Of Month
Philadelphia
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
   / Anyone DIY dye their hydro oil? #2
My tractor has a dipstick, so I don't need to dye mine.
I've read here on TBN that John Deere sells a dye specifically for hydraulic systems.
   / Anyone DIY dye their hydro oil? #3
I use the JD dye. It works, turns the oil red. Does not take much. My L3600 has a sight glass, could not see the oil without the dye. Easy, just pour it in. Might mix with some of the oil to pour easier.
   / Anyone DIY dye their hydro oil? #4
Did you get that local or order it online? I have been wanting to add some to my tractors.
Mine has a dipstick, too! But both sides are cross-hatched, there's no smooth side for viewing the "wetted" line. Just about impossible to see the fluid without walking out to daylight with the dipstick in-hand.
   / Anyone DIY dye their hydro oil? #6
I ordered mine online, but you can find it locally also. I used more than was needed also - just use use a tad bit of it and it works fine.
   / Anyone DIY dye their hydro oil? #8
I got it online from a tractor store. It was silly expensive on Amazon. Little bit goes a long way. My Kubota has the impossible sight glass. It must be a Japanese thing. My Yamaha has one too :rolleyes:
   / Anyone DIY dye their hydro oil? #9
JD sells it, it's expensive per ml, you might get 2 fills out of it but they suggest it's for 5 gallons (if it's pasty or dried up, add hydraulic fluid and stir!) ... I bought mine from https://www.zoro.com/kingscote-dye-...red-4-oz-506250-r4/i/G5130815/#specifications (I bought some gloves also to bump total up to get "free shipping!")
Wear gloves, I recommend pouring/dripping it into the jug, then pouring into tractor ...
2 drops per gallon ...
Decorative Deer Statue (A55758)
Decorative Deer...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
