Does anyone have a low-temperature alarm in their barn?
/ Does anyone have a low-temperature alarm in their barn? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Does anyone have a low temperature monitor in their barn that rings in the house if the temp falls too low? I just insulated a barn and need something to notify if it drops below a certain level, maybe 40 degrees.
/ Does anyone have a low-temperature alarm in their barn? #2
Yes, tied into our home alarm system.
/ Does anyone have a low-temperature alarm in their barn? #4
Look at amazon, product called yolink
They have huge range and will alert your phone, email or an alarm.
You need at least 1 hub and you connect hundreds of devices to it. I also use mine to turn on tractor heat in winter
/ Does anyone have a low-temperature alarm in their barn? #7
What I bought and use, the package I got comes with three sensors and the base.
I have one in the lower portion and one upper (3rd one I have not used yet).
This way I can set a lower alarm (had a burst pipe last year due to the heater shutting down).
I can also compare downstairs to upstairs to make sure heat/cool settings are not too far off.
/ Does anyone have a low-temperature alarm in their barn? #8
We have blink cameras, they will monitor temps and alert if too hot or too cold also
/ Does anyone have a low-temperature alarm in their barn? #9
I would like to do the same. I have issues but my barn is a few hundred feet from my house.
I have unobstructed line of sight between the two structures but likely pushing 400'.
/ Does anyone have a low-temperature alarm in their barn? #10
I have a set of temperature and humidity sensor tied into a networked weather station. Brand is La Cross.
Pushes alerts for low temperatures. I have sensors at the front, rear and middle of my shop since my mini split is at the rear of the shop and there can be quite a differential between front and rear ([emoji6]x garage door at front certainly doesn’t help with the differential!!).
/ Does anyone have a low-temperature alarm in their barn? #11
Like i said, the yolink devices from amazon will work. My building is about 500’ from the hub, never disconnects.
This is what I'm thinking of. One pack with hub. My barn is 30 ft from the house but is a metal pole barn and I presume that's no problem. Does this below look suitable for telling if the temp starts to get to maybe 40 degrees?
/ Does anyone have a low-temperature alarm in their barn? #13
You can set whatever levels you want to be alerted to. But this link didnt have a hub.
Underneath it does show the item with a hub for a higher price. I think it's $35 or so.
/ Does anyone have a low-temperature alarm in their barn? #15
The product he linked to says it uses LORA communications. 400' distance should be no problem.
This is what I bought. YoLink. I have the hub in the house and put a temp sensor in the barn.
I do have one issue in that I only get intermittant readings, usually when the furnace kicks on or the alarm sensor goes off. I figure the metal barn, that is also insulated, is maybe blocking the wifi signal. Does that sound likely and is a signal booster worth a try?
I've tried moving the temp sensor and tried moving the wifi and hub in the house where it is only 40 ft from the barn so I don't think it is the distance. On the other hand, how could I get those intermittent readings but not continuous readings?
YoLink is a great product for my purpose and fast install.
/ Does anyone have a low-temperature alarm in their barn? #17
I do not know, mine never gives me any issue. My hub is about 40 feet from the wifi router. But i have overall 20 separate sensors made up of leak detectors, temp sensors, switches for tractor and truck preheats, etc spread throughout property. I have been told the devices link together to help spread signal. The wifes temp sensor in greenhouse and potting shed are encased in steel buildings, and have no issues. The switch for my diesel truck preheat is in a steel building over 350’ from the hub. Works great.
/ Does anyone have a low-temperature alarm in their barn? #18
I have this one. It works well.
Any chance I could have a bad sensor? When I first plugged it in, it ran continuous but then started acting odd with only intermittent transmitting
/ Does anyone have a low-temperature alarm in their barn? #20
Might be, contact them . I had a bad hub about 3 months after i bought mine, they replaced it free. That was 3 years ago.
KUBOTA FRT LOADER ATTACHMENT (A62130)
KUBOTA FRT LOADER...
UNUSED WOLVERINE SP-15-84W 84" SNOW PUSHER (A62131)
UNUSED WOLVERINE...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
Ferris Z3X Lawn Mower (A61166)
Ferris Z3X Lawn...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A62131)
UNUSED JCT 84" HYD...
2014 Jeep Grand Cherokee SUV (A61569)
2014 Jeep Grand...
