Does anyone have a low-temperature alarm in their barn?
   / Does anyone have a low-temperature alarm in their barn? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Does anyone have a low temperature monitor in their barn that rings in the house if the temp falls too low? I just insulated a barn and need something to notify if it drops below a certain level, maybe 40 degrees.
   / Does anyone have a low-temperature alarm in their barn? #2
Yes, tied into our home alarm system.
   / Does anyone have a low-temperature alarm in their barn? #4
Look at amazon, product called yolink
They have huge range and will alert your phone, email or an alarm.
You need at least 1 hub and you connect hundreds of devices to it. I also use mine to turn on tractor heat in winter
   / Does anyone have a low-temperature alarm in their barn? #7
What I bought and use, the package I got comes with three sensors and the base.
I have one in the lower portion and one upper (3rd one I have not used yet).
This way I can set a lower alarm (had a burst pipe last year due to the heater shutting down).
I can also compare downstairs to upstairs to make sure heat/cool settings are not too far off.
   / Does anyone have a low-temperature alarm in their barn? #8
We have blink cameras, they will monitor temps and alert if too hot or too cold also
   / Does anyone have a low-temperature alarm in their barn? #9
I would like to do the same. I have issues but my barn is a few hundred feet from my house.
I have unobstructed line of sight between the two structures but likely pushing 400'.
   / Does anyone have a low-temperature alarm in their barn? #10
I have a set of temperature and humidity sensor tied into a networked weather station. Brand is La Cross.
Pushes alerts for low temperatures. I have sensors at the front, rear and middle of my shop since my mini split is at the rear of the shop and there can be quite a differential between front and rear ([emoji6]x garage door at front certainly doesn’t help with the differential!!).
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
CATERPILLAR D6 LGP...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
CATERPILLAR 299D SKID STEER (A60429)
CATERPILLAR 299D...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
