pulling well pump, no pitiless adaptor?
   / pulling well pump, no pitiless adaptor? #11
I see Finley Well & Pump still is in business in Bellville OH - If this is likely the driller a call to them on Monday AM about this might be time well spent.
The "hex" nut may be a pulling point or an older pit type adapter, but I used pitless adapters in PA in the late 70's.. so they should have too.
   / pulling well pump, no pitiless adaptor? #12
Interesting, a licensed driller installed the pump and no pitless. Don't understand that at all. I'm puzzled.
Had the same guy who put the well in back in 85 put in the mew pump. cost me more than I was indicated it would. 1400 with new pump and 54feet of line. old pump was put in back in 98 or so.
the well did have a pitiless adapter but was a 0 clearance type that has the wedge thru the casing sidewall so a pump slides by. never knew they had such a thing to let you install a 4" pump in a 4"pipe.
mark
   / pulling well pump, no pitiless adaptor? #14
Down here in the south they don't seem to install pitless adapters I guess it's since freezing isn't an issue.
   / pulling well pump, no pitiless adaptor? #15
The whole idea behind a pitless adapter in the north is that the supply line must exit the well casing below the frost depth if we expect to have running water in February :). Mine is down 5'-6' feet for example.
The adapter allows pulling the pump for service without having to dig down beside the well casing.
In the south, I suppose your supply lines exit the well casing at the top or at very shallow depths, so there isn't much need for the pitless adapter.
Dave.
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
UPS and Power Supplies (A56860)
UPS and Power...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
