Treating trailer deck; UNDERNEATH
/ Treating trailer deck; UNDERNEATH #1
Rvrrat14
Texas
Yanmar YM347A Bush Whacker HD72 shredder, Armstrong BGR64-5 grapple, E.L. Caldwell 66” box blade, Advanced Earth 48” pallet forks, 43x45 Safety Basket
How many of you treat the wood of your deck on the underside? I was thinking of doing my new trailer and lifting with forks, blocking, and rolling the underside. Any suggestions or how-to’s to insure a safe work environment is appreciated. I’ve got some old 2 stroke oil, diesel, and used motor oil.
Thanks!
/ Treating trailer deck; UNDERNEATH #2
I use a mix of diesel and used oil in an old garden sprayer and while I may not get a perfect coating at least it is something.
I was able to lift tongue and place safety saw horses under tongue area, as well as drop tongue jack all the way down. Crawled underneath with roller/long handle/rough nap roller; Old Yamaha 2M 2-stroke oil/Diesel 50:50. Two coats top and bottom. It soaked up well.
/ Treating trailer deck; UNDERNEATH #4
I'm in the process of replacing my trailer decking, switching from PT YP to white oak. I just picked up a gallon of Thompsons, with which I'll treat both sides and edges before installing.
I'd never use a water sealer on S4S YP, it'd be as slippery and dangerous as an ice rink. But I'm figuring the rough grain of rough-sawn white oak is going to offer enough grip to compensate the water seal.
If I'm wrong, no biggie. The clear stuff I'm applying usually only lasts 2 years or less on upward-facing horizontal surfaces.
/ Treating trailer deck; UNDERNEATH #5
I think and know it's more important to treat the steel. Something like woolwax will do wonders to save the steel. I do mine every other year.
The wood on mine I dont think about much as I have had normal non PT wood last over a decade before selling the trailer. Since the underside sees no UV and very little water I wouldnt worry about it to much. There are alot more important areas to take care of.
/ Treating trailer deck; UNDERNEATH #6
I think it depends on storage location. The PT yellow pine wood deck rotted out on my trailer after just 8-9 years, but I store in a cove in the woods to keep sun off the tires, paint, and wiring. Steel still looks great, only very minor surface rust on brakes and anywhere it's been scratched, but paint is holding up fine. But the constant shade and leaves means the wood doesn't dry out quickly between storms, and there's also constant moisture evaporating up from the ground beneath.
Out in the sun, the deck might last 50% to 100% longer, but I'd be replacing dry-rotted tires, lights, wiring, etc.
/ Treating trailer deck; UNDERNEATH #7
But then again if its left in the sun you get alot of UV damage and cracking allowing moisture way in the wood.
I currently have a 3yr old PT wood deck. Never coated the bottom and 1x the top with motor oil. I see no major damage and where physical damage has occurred it looks like new wood. I dont see how this deck would go bad in 8-9yrs as I'm 1/4 the way there.
/ Treating trailer deck; UNDERNEATH #8
I've had my 30' gooseneck trailer about 12 years with the original decking and never painted anything on it but it's a fair weather trailer. I only use it in nice weather and it's parked in my barn at all other times.
/ Treating trailer deck; UNDERNEATH #9
It'll be interesting to find out! I'd have said exactly the same, right up thru year 7 or 8, as it felt solid one day, and then spongy the next time I pulled it out. A few months after that, my foot went thru a board.
IOW, it went from seeming 100% to shot, real fast. Not much in the way of warning signs.
/ Treating trailer deck; UNDERNEATH #10
I'd love to have another barn, with room for my trailers. Unfortunately, it's cheaper to replace trailers every 20 years, than build one barn. :ROFLMAO:
/ Treating trailer deck; UNDERNEATH #11
You mentioned treating the underneath, but is the top treated as well ? Does wood need to breath ? Would sealing both sides do more harm than good ?
/ Treating trailer deck; UNDERNEATH #12
Transparent sealers are mostly boiled linseed oil, which saturates the surface of the wood with oil as a method of displacing water and preventing the wood fibers from soaking up water by mechanical capillary action. Put otherwise, is the capillary gaps in the fibers are already saturated with oil, there's little room for water to attach.
But I don't think it really inhibits the escape of trapped moisture in any way that's going to shorten the life of the wood. I suspect coating all sides is better than not, even after scratched and abused, as long as the sealer is mostly just oils without solids that form an impervious coating.
Your theory of a coating trapping moisture might be more applicable to something like latex paint, which does dry to a rubber coating, similar to a latex glove. In that case, water intrusion may be trapped in the wood. But I don't think BLO or transparent sealers behave this way.
Some of the opaque wood deck stain products may be more similar to latex paint, tho... choose accordingly.
/ Treating trailer deck; UNDERNEATH #13
I paid $30,000 to build a 56'x40'x14' barn with cement floor 15 years ago and thought it would never be worth it. I was wrong, with prices now it was well worth it. Every thing in my barn will probably outlive me. I just traded my 28 year old Ford F150 for a new truck. There was only rust on the frame because it was always parked inside and salt was rinsed off ASAP in the winter.
/ Treating trailer deck; UNDERNEATH #14
BLO is a crap product for exterior protection. Mold grows on the stuff and can cause rot. Not to mention you would need to apply it every year to do anything at all.
Motor oil works just fine and it's free. If you feel the need to buy something a oil based stain from the log home industry is also a good choice. How ever I have used both on the same trailer and found motor oil lasted longer and repelled water longer.
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
2014 Chevrolet Cruze Sedan (A61569)
2014 Chevrolet...
2019 Kia Sorento AWD SUV (A61569)
2019 Kia Sorento...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A62131)
UNUSED WOLVERINE...
2021 Ram ProMaster 2500 Cargo Van (A61568)
2021 Ram ProMaster...
(2) 23.1-26/18-26 TRACTOR TIRES (A62131)
(2) 23.1-26/18-26...
