Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...?
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #11
I have multiple trailer decks that are coated in motor oil and even a shed that's stained with motor oil.
Last year I used a very expensive ($75 gal) oil based log home stain on my 1yr old trailer deck. This year it's starting to look weathered so I coated it in used motor oil. I did move skids of concrete and enough lumber to build a 3br cabin useing this trailer in the last year.
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #12
Used motor oil use it on the flat racks and the trailer. Do it on a warm sunny day in direct sunlight. If you have to do every few years it only costs you the time to apply it.
So, I went last Saturday and ordered an Amish built 24' X 12' shed. I talked to the fellow making the sheds, and he stocks used oil and offered to spray it for me for a price. I declined, as I can do it myself easy enough with a garden sprayer.
His opinion is that some of his sheds on the farm are oil brushed by his relatives 50+ years back and still there. He said that it is a very common thing for Amish to do and has been for decades. Sounds like the path to take.
I am getting 4 24"x36" windows, 80" double barn doors, 40" man door, extended eves out 14" from the building walls, and for $3200 plus $400 for the local shed mover guy to pick it up and place it. I told him to have it ready for the end of May. I am excited for the shed at my cabin to have a place to store things inside, stack and air out Amish rough cut lumber, get my lawn tractor and pellet smoker inside and I am going to frame in a shower room with an 2.64 GPM portable propane instant water heater.
This will make the camp/cabin much better.
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #14
There is an old farmhouse on my property. When the house was built over a century ago, they used motor oil on the exterior clapboards. The clapboards are still solid.
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #15
A garden sprayer wont spray used motor oil very well. They tend to clog prety easily. I suggest something like a HVLP gun or a airless sprayer. Both are very cheap from harbor freight. Either way buy your self a $13 stain brush and back brush every inch of the shed. The brush really helps soak the oil into every crack and crevice. Letting the wood dry a few months prior to staining may also be a good idea.
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #16
change the oil in a motor and while its hot go dump it on the trailer floors and mop it around!!!!!!!!!!!!!!!!!!!!!!!
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #17
I have been using a 50/50 mix of diesel and used motor oil on every trailer I have had and not once have I had to replace a floor. I put it on using a long nap roller on a miserable hot sunny day, it soaks in leaving a slightly brownish color.
I also use NEW motor oil and enough diesel fuel to make it come out of my pump sprayer. I have never replaced a trailer deck. I apply it every spring.
I use the cheapest motor oil I can find.
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #18
Doesn't using motor oil make the trailer deck slippery when wet?
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #19
I spray mine with Thompson's WaterSeal using a garden sprayer.
   / Trailer wood deck treatment: Brush on used oil, linseed oil, sealer stain, unicorn tears...? #20
Been using 50/50 motor oil & diesel on my trailer floor and have yet to have it be slick when wet. Just gotta let have time baking in the hot sun.
DESCRIPTION & ANNOUNCEMENTS (A43004)
DESCRIPTION &...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A42742)
2025 Kivel 48in...
Freightliner 122 SD Truck (A42203)
Freightliner 122...
CAT IT28 Wheel Loader Pallet Forks (A44391)
CAT IT28 Wheel...
2014 CAT 336E LH (A42021)
2014 CAT 336E LH...
Walk-Behind Brush Cutter (A44572)
Walk-Behind Brush...
