Top and Tilt on the left side?
/ Top and Tilt on the left side? #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
Fellows, I'm in process of installing top and tilt cylinders on my JD 110TLB. I noticed in every picture of other tractors the tilt cylinder is always on the right side. Is there a reason? Is there any issue with installing the cylinder on the left?
I am running hard lines to the quick couplers. Installing the tilt cylinder on the left side will give more clearance for the quick couplers on the right.
/ Top and Tilt on the left side? #3
It doesn't matter. I put mine on the right because I typically push my back blade down on the right. It's just seems easier for me to turn and see it on the right since my valve handles are on the right too.
When I first installed the hydraulic tilt, I put the original manual adjuster on the left. I can't remember why. I think because I didn't really know where "level" or "center" would end up.
/ Top and Tilt on the left side? #5
Typically, the cylinder is installed on the left and the manual adjusting link is left on the right, but it does not matter other than the length and routing of your hoses.
Well this is contradictory to what I have noticed. In fact after searching for several minutes, I was unable to find a picture of a lift cylinder installed on the left.
/ Top and Tilt on the left side? #7
Ever try to operate the 3-pt. controls while looking over your left shoulder and step on the clutch and brake at the same time?
I looked over my right shoulder for so many years my back slips nearly every time now, then I have trouble walking with the sciatica nerve yelling at me.
I'm on a first name basis with my chiropractor.
/ Top and Tilt on the left side? #8
It is the way Ford skips were setup for years before double tilt cylinders were installed.
If the adjustable link is set with the tilt cylinder at midpoint, you can tilt left or right equally. .
/ Top and Tilt on the left side? #11
There is/was a TBN member here who had a tilt cylinder on both left and right sides.
Is there value to do this? I have thought about it a few times.
Maybe not the member that @von-mil was thinking of but I have dual tilt cylinders. I use a Land-Pride back blade extensively for "landscaping" and the dual cylinders allow me to easily change the angle to +/-15 degrees. This is great for ditches and swales and also allows me to break up my damned clay "soil" with the corner of the blade.
/ Top and Tilt on the left side? #12
Here's some photos:
/ Top and Tilt on the left side? #13
I believe the reason he gave for a tilt cylinder on each side was so that if he raised both sides up fully, he could be assured that the attached implement was perfectly level. Then the 3PH could be raised and lowered as desired.
/ Top and Tilt on the left side? #14
Sounds reasonable. Particularly when The blade does not have a built-in tilt feature.
159115 (A60430)
159115 (A60430)
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2022 John Deere Z920M Zero Turn (A63116)
2022 John Deere...
(APPROX. 10) 12' - 29GA GALVALUME (A63290)
(APPROX. 10) 12' -...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2008 Unverferth 220 Rolling Harrow (A63116)
2008 Unverferth...
