SpeeCo Quick Hitch Top pin question
/ SpeeCo Quick Hitch Top pin question #1
JimFromTN
2019 Kioti CK3510
I am a new tractor owner and have little experience. I bought a kioti ck3510 last year. I have driven other peoples and I have rented tractors. I decided to get a quick hitch and saw the great reviews speeco have gotten so I ordered one. I received it and I went to install and the standard 3/4 in pin went through one hole and not the other. I googled and could not find where anyone talks about a tapered pin for the top link. I called speeco and they said a standard 3/4 inch top pin should fit it. They told me to send it back. I sent it back and got another and it was the same with the exception the the hole that the 3/4 in pin fit in was even tighter. Again, I called speeco back and again they said a standard 3/4 in pin should fit. I measured the pin I am using with calipers and it is 3/4 inch. Am I missing something or am I just really unlucky?
/ SpeeCo Quick Hitch Top pin question #2
I'd guess poor manufacturing tolerances or excessive powder coating on the holes. Just ream the holes a bit and the pin should slide right through.
I would have thought that but in both cases, it was the same hole which was too small. I am not sure that just removing the powder coating will be enough. The hole may need to be drilled out which I was trying to avoid in case something else may be wrong with it which may require I return it.
2020 Kubota MX5400DT (A64047)
2020 Kubota...
2008 CARRIAGE CAMEO 5TH WHEEL CAMPER TRAILER (A63569)
2008 CARRIAGE...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
25FT FLATBED DOVETAIL TRAILER (A63569)
25FT FLATBED...
