   / Your last generator Maintenance Run #7,721
I think the reason the PS Audio product is so expensive is that is is active, not passive. It will correct low voltage, not just alarm on it.
so they call it a power regenerator. It generates 2kw of sine wave power, not just filtering another source and done not by battery power like an inverter. Yes I believe as one of my friends has said this is the audio equivalent of cork sniffers in the wine world...
Ferroresonant Transformer, and yes you have to admit that someone that will pay $100’s of dollars for a high end IEC power cable that plugs into hundreds of feet of romex in their house before connecting to the power grid might be an “audiofool”.
Saying that they hear a difference confirms it.
   / Your last generator Maintenance Run #7,722
in this case they are eliminating the entire power feed and recreating it I believe.
so wires into house irrelevant if they are starting over
Ferroresonant Transformer, like the old buzz box golf cart chargers and welders?
I have two of the CyberPower 1500 VA units, a new one on my wifes work computer and a several year old model on my router/modem wifi and switch setup.
I'd like to get a bit more battery for my old one but it does about 45 minutes after a power outage. Of course with this new mesh router system only the main unit is ups powered
Needed a new ups in a hurry before leaving on a trip 2 or so Summers back, so ended up ordering a 1000VA APC of Azon. Still good battery life, 90++ minutes for router etc.....
That ^ worked out well, but if the company I used to deal with years back is still around (there will be others today if not), I always wanted to move up to a lightly used large UPS (data centre stuff). They used to get cycled-out fairly often (high reliability sites) and made their way into secondary markets. What I like about those (aside from VA), is they are designed from the start for large expandable battery arrays.
Another one of those projects, On The List.....
Rgds, D.
No high-frequencies in one ear now, so I wouldn't even try to rate audio systems today..... but these conversations are reminding me of the Foster's commercial Back When..... :cool:
Rgds, D.
   / Your last generator Maintenance Run #7,725
Honda eu3000i that belongs to my buddy that’s built my house and onto another one on this Amsoil. Doesn’t look bad for likely 150 plus hours. Amsoil Small Engine 10w30 out, ASE back in…all of .6 qts 😉
Changed the NGK plug at the same time.
View attachment 3929819View attachment 3929820
(y)
They used to have a straight 30w oil, but I don't think that's available anymore (?). I liked that one, for air-cooled units.
(Perhaps just an SAE grade-shuffle ?).
Rgds, D.
   / Your last generator Maintenance Run #7,727
(y)
They used to have a straight 10w oil, but I don't think that's available anymore (?). I liked that one, for air-cooled units.
No way in h&ll I’d ever run a straight 10w oil in any of my engines, especially not an air cooled engine.
I’m guessing you mean a straight 30w. That would make some sense
I shouldn't type b4 coffee :rolleyes:
Yep, I was thinking straight 30 - used it in my push mower, with now old Briggs. That one doesn't use a lot of oil, but def less consumption with the Amzl straight 30.
Rgds, D.
   / Your last generator Maintenance Run #7,729
Well giving my pto genset it's exercise run today. Nice sunny comfortable day and all of a sudden no power.
UPS's working for my wife's computer and theother one working on half of the new mesh router and Starlink.
Stayed good for about 40 minutes then the old unit ran out of power, I should replace those batteries I guess. So fired up the IH574 and backed up to the house. It was time for the freezers and water pump anyways. Just went down and looked NO National Grid trucks in sight, I can see the broken wire laying in a corn field just a ways from the road. Supposed restoration at 1:45, they had best get their butts in gear if that's going to happen. One good thing it's been so dry they shouldn't have any trouble getting into and through that corn field. Going to mess up a lot of corn :( for my neighbor.
   / Your last generator Maintenance Run #7,730
Yeah, utility easements through farmland can definitely have an affect on the harvest. My FIL had a gas pipe under one of his corn fields. In 2012, the gas company decided to replace it in the middle of the growing season. He lost close to 10 acres of corn due to all the construction equipment. He tried to recover his loss but the gas company refused quoting fine print in the easement agreement. He was able to make a claim on his crop insurance but it only covered about 25% of the loss.
Good luck Lou,though with the IH etc you'll be fine anyway ! Clear weather, sometimes gives us the longest outages...
That story bdh, sure sucks.... not like Farming is an easy-go, to begin with !
Rgds, D.
   / Your last generator Maintenance Run #7,732
Rgds, D.
Generator exercising over and done with utility power back at 4:42, so from 10:10 AM til 4:42 PM, on the generator about 11AM till almost 5PM so about 6 hr's.
Just about the lightest load that unit ever see's. No heat or AC, just lights, computers, freezers and water pump.
Could get by with a 6kw unit, tractor was sure loafing along 6 hours at pto speed temp stabilized out at 170 and 50 psi oil pressure.
I've thought about taking the little backhoe of the Kioti 25 hp so it would be available for the generator, should be able to push 10-12 kw out of the generator.
The Branson does it easily on the 540E, I'll have to try the NH some day with the 1000 rpm pto at half throttle and see if the governor is stable enough.
   / Your last generator Maintenance Run #7,733
Lou, if your diesel got up to 170, should be hot enough to avoid stacking
nice easy work for your old girl
maybe throw the a/c on just to load it up for a little bit?
   / Your last generator Maintenance Run #7,734
Glad you're back on the grid.(y)
Having multiple tractors is indeed a blessing but it sometimes becomes a question of what implements to leave attached.
I have more power outages than uses for the backhoe, but the implement swap time on my first tractor becomes an issue. I mow & plow more than I need the generator, so leaving it attached to the second tractor isn't practical. I thought about a third tractor that I could dedicate to the PTO genny, but I decided to spend the $$ on a standalone diesel generator instead. It isn't quite as portable as the PTO model and it's a one trick pony, but it does have wheels and can be moved with forks if necessary. The slight loss of flexibility is more than made up in the convenience of just throwing a switch to get the juice back on.
In my younger years, I wouldn't have thought twice about taking off an implement and hooking up the PTO genny, even for a half hour outage. Back then, I did very well with just one tractor. Unfortunately, age is a cruel master and forces us to compensate as best we can.
Decision-trees..... should be capable of adapting, for all of us.....
Thinking about knowledge vs Wisdom, reminds me of that Will Rogers quote (paraphrasing...)
Knowledge: Knowing what an electric-fence is.
Wisdom: Deciding not to **** on it. :cool:
Rgds, D.
   / Your last generator Maintenance Run #7,736
no joy this afternoon on a test
light under start push button should light up when rocker switch turned to on.
Doesn't.
won't start manually.
am thinking bad rocker switch, sprayed some contact cleaner in, no joy.
hoping a friend can take it apart tomorrow and we can determine where power is stopping.
there is a big blade fuse on the starter and that was fine.
   / Your last generator Maintenance Run #7,737
Doesn't.
Did you check the oil level?
   / Your last generator Maintenance Run #7,739
thanks, I did. Nothing loose, oil at full level
will check again today
   / Your last generator Maintenance Run #7,740
what I am going to do after watching several YT videos is disconnect the low oil sensor.
apparently engine runs just fine with it disconnected and that part is known to fail.
The yellow wire is easy to find, just need to trace it back to disconnect plug.
not impressed with rust resistance on this unit, granted it's been outside for four years but has always been covered.
looks like I need to wipe down some of the front panel hardware with oil.
I do inspect the receptacles and have plugged and unplugged the 50 amp cord,plus DeOxit.
And I use a plastic/metal protectant on the frame.
but the rust around the push button breakers is unfortunate, likely due to our wet Spring here.
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A59905)
2015 UTILITY VS2RA...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
(2) 6 LUG 5200Ib-74SC-93 HUB FACE AXLES (A60432)
(2) 6 LUG...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
