Oil leaking from brake dust cover
   / Oil leaking from brake dust cover
Is it a power shift or geared transmission?
This weekend I'll take photos of everything and upload them to clear up any doubts. I can't tell you if it's powershift or geared. My mechanical knowledge is very basic.
   / Oil leaking from brake dust cover #23
A photo of the engine plate / tractor identification plate would help.
Is there a possibility that the equipment might be different in Europe vs the US?
All the best,
Peter
   / Oil leaking from brake dust cover #24
We need the engine ID plate. This will tell what you really have.
I'm very suspicious of the model ending in DT. The D means 4WD and the T turbo. There are no turbos on models less in the YM series of a YM2500.
I've seen models ending in A, B, D, F, M, R, S, T and Z.
these are the photos
   / Oil leaking from brake dust cover #27
I am thinking you have a1602D.
Agree.
YM1610 has PowerShift. The floor shifter has 3 speeds. (No-clutch shifting).
That photo shows a shifter with 4 speeds. (Manual transmission).
Both have another shifter on the side to choose a range.
Okay, so what procedure should I follow to refill the oil?
What oil should I use to refill it?
Should I change the filter in the photo?
Should I add some kind of detergent oil first to remove impurities before adding the final oil?
What kind of oil would that be?
   / Oil leaking from brake dust cover #29
What condition was the fluid in? Any idea about last fluid/filter change? If not then yes, change both.
I do not have access to a 1602 parts manual but here is what I think. I circled what I believe might be the flange that covers your internal suction screen. That screen would need to be cleaned. If no knowledge of last screw on filter change then it likely should be changed. No idea what condition your used fluid was in so I can't really advise a flushing. If everything was pretty clean looking I probably wouldn't do any flushing. A universal transmission/hydraulic fluid is recommended. No idea what you have access to in Spain, maybe Maverick will help you with that.
   / Oil leaking from brake dust cover #30
OK, after looking at all the photos, this machine is mis-marked.
This a VN imported machine.
The engine ID plate is exactly the same as a YM1602D.
Your image,
A Fredricks restored YM1602D, like @winston1 pointed out,
Your layout of controls by the seat 100% match a YM1602, not a YM1610 nor a YM1601.
Your image,
   / Oil leaking from brake dust cover #31
The gray market YM1602D is very much like the domestic YM220D with the white headlamp fascia. The early YM220D machines are a little different.
The dash layout is even very similar, the seat controls are nearly the same, and the engine is in the same family series.
   / Oil leaking from brake dust cover #32
YM1601 4WD. 19 Eng. HP. 3 Cyl. Gear Drive. Prod. Yrs. 1979-81
YM1602 4WD. 19 Eng. Hp. 3 Cyl. Gear Drive. Prod. Yrs. 1982-83
The YM1610-1610D Eng.19 Hp. 3 Cyl. Power Shift. Prod. Yrs. 79-81
The Ym1601 1587Lbs. and the Ym1602 1521Lbs. I thought that was odd.
66 Lbs. lighter ?
I show the Hyd. Screen for the YM1602. #HS.4430.
Not showing the YM1601.My guess the YM1602 the same Filter Screen.
YM 1601-1610 Same Hyd. pump #HP-5C.
I use JD,303 equivalent. in my 4spd. Ym2000 Tractor Supply Universal.
I removed the filter you mentioned and cleaned it.
I also removed that filter thinking it had the reference number written on it, but it's completely painted over, so I can't see the reference number.
Can you tell me the filter reference number?
What system do these two filters I removed correspond to?
   / Oil leaking from brake dust cover #35
the strainer and spin on or both for the transmission/hydraulics. This is the filter I used on my old 2002D. I have no way of knowing whether it would fit your 1602D or not. I can only suspect it would. If you could compare the part # for the 1602 and 2002 you could know for sure. Just make sure you get a filter with a good flow range.
This information says they use the same filter. Yanmar Tractor Hydraulic Filter, Spin-on Replaces 194250-48310
Ok, thanks, winston1
I see that John Deere 303 oil is no longer sold and its replacement must be John Deere HY-GARD.
Is this correct?
I found this online store in Spain where they sell it:
   / Oil leaking from brake dust cover #37
Is this correct?
Yes, Yanmar TF500A or Deere Hy-Gard are suitable for your machine. (y)
I can't find that filter (WIX 51203) in Spanish online stores.
Do you know the reference number of an equivalent filter?
   / Oil leaking from brake dust cover #39
FWIW: but please verify that the thread and dimensions match.
I find that the store based cross reference to be generally more accurate, but they often over look possible filters.
All the best,
Peter
   / Oil leaking from brake dust cover #40
Just make sure you get a filter with an equivalent flow rating. many will screw on which is important, but also important not to choke your pump. with inadequate flow.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
FENCE PANELS (A58214)
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2011 JLG E400AJP MAN LIFT (A60429)
2011 JLG E400AJP...
Mini Margaritaville Truck (A55853)
Mini...
