GM recalls 721K trucks with 6.2L engine
/ GM recalls 721K trucks with 6.2L engine #101
Show me all the windowed cummins blocks.
Are you saying it didn't happen?
SR
What is the % of all produced Cummins inlines??
Wow in other News GM truck owners get screwed, in GM lawsuit being "decertified" concerning the 8 speed, and the 10 speed may be next.
Nate lets them have it.
/ GM recalls 721K trucks with 6.2L engine #102
It is being made for the medium duty truck market, not PU's.
B6.7 Octane​
The Cummins B6.7 Octane engine is specifically designed and developed for the medium-duty market while achieving 2027 EPA and CARB compliance.
https://www.cummins.com/engines/octane
Uh, UIAM ALL ISB Inline 6 Cummins are considered Medium Duty Engines already.
New reports RAM HD's will get the New B7.2 Cummins inline 6 in 2027 Not sure about going with OHC on either but the Octanes numbers are impressive and hard to argue with for low end torque...
/ GM recalls 721K trucks with 6.2L engine #103
B6.7 Octane​
So is the 5.9/6.7 Cummins, but they put them in light duty trucks anyway.
99% of truck buyers would be happier buying a light duty truck with a medium duty rated engine than a light duty engine.
/ GM recalls 721K trucks with 6.2L engine #104
I didn’t know Cummins bought the Jacobs Engine Brake Company (Jake Brake) in 2022.
That’s a huge move.
/ GM recalls 721K trucks with 6.2L engine #105
/ GM recalls 721K trucks with 6.2L engine #106
Drat! I was already drooling over buying one.
Just because it's Medium duty, it doesn't mean it won't be in a Ram.
Ram already has a medium duty diesel in its Ram 2500-5500
/ GM recalls 721K trucks with 6.2L engine #107
The Dealer just completed the recall on the L87 6.2L engine in my 2022 GMC Sierra 1500, and it checked out ok. They replaced the oil fill cap & filter, Changed the oil to a heavier weight and listened to the engine with a fancy type of stethoscope. Pretty much what the recall notice said.
Still a bit nervous driving it though, listening for any unusual engine sounds. The good news is, I'm covered if there should be a future failure specific to the recall. It's important to keep records proving you used the right oil type though if you change your own oil.
Only a 3% failure rate though so the numbers are on my side. Too bad about the hit on the trade in value.
/ GM recalls 721K trucks with 6.2L engine #108
Medium duty, as in: It makes no sense to put a cast iron lugger in a half ton. It doesnt give high horsepower but it will deliver longevity and torque in a towing truck.
/ GM recalls 721K trucks with 6.2L engine #109
Man suffers most from what he fears (but never happens)
I have a very quiet whine in the transmission, which only i hear. I can worry about it grenading the bearing rollers through the front wall, into the bellhousing, bending the clutch bolts while being pushed through that sidewall too, like i had 21 years ago, but thats an unrealistic expectation...
/ GM recalls 721K trucks with 6.2L engine #110
When did I say “half ton”? I said 2500-5500.
Read much?
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2014 FORD F-150 (A60736)
2014 FORD F-150...
500BBL SKIDDED FRAC TANK (A60736)
500BBL SKIDDED...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
207278 (A52708)
207278 (A52708)
Iron Bull Trailer (A60462)
Iron Bull Trailer...
