2011 JD 2520 Left Rear Marker Light
/ 2011 JD 2520 Left Rear Marker Light #1
jcalla
Triangle, VA
No power getting to my left rear marker light when I turn on my lights. Bulb ok. Any test points suggestions?
JPC
/ 2011 JD 2520 Left Rear Marker Light #2
Any chance you have the service tech manual ??
Can you follow the wire back a ways to a connector ?
Just bought this used. No tech manual.
/ 2011 JD 2520 Left Rear Marker Light #4
Test the contact points in the bulb socket with a DMM, if you don't get any voltage reading, try a different ground point. If you get voltage, the fixture had a bad ground, if you don't get voltage, you need to chase the wiring upstream to find the fault. It'll probably be in a loom, so check pinch points and where it goes through panels and might get abraded.
Already checked out ok as suggested. Just wondering if someone had similar situation. If it was short to ground I believe fuse would be blown. I'm thinking open somewhere. No manual, open to suggested test points.
/ 2011 JD 2520 Left Rear Marker Light #6
The service tech manual will be a good thing to have, one dealer service will pay for it, just sayin....
Topsoil Trommel (A57453)
Topsoil Trommel...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY  CAB (A59905)
2018 FREIGHTLINER...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
