2011 JD 2520 Left Rear Marker Light
   / 2011 JD 2520 Left Rear Marker Light #1
jcalla
Triangle, VA
No power getting to my left rear marker light when I turn on my lights. Bulb ok. Any test points suggestions?
JPC
   / 2011 JD 2520 Left Rear Marker Light #2
Any chance you have the service tech manual ??
Can you follow the wire back a ways to a connector ?
Just bought this used. No tech manual.
   / 2011 JD 2520 Left Rear Marker Light #4
Test the contact points in the bulb socket with a DMM, if you don't get any voltage reading, try a different ground point. If you get voltage, the fixture had a bad ground, if you don't get voltage, you need to chase the wiring upstream to find the fault. It'll probably be in a loom, so check pinch points and where it goes through panels and might get abraded.
Already checked out ok as suggested. Just wondering if someone had similar situation. If it was short to ground I believe fuse would be blown. I'm thinking open somewhere. No manual, open to suggested test points.
   / 2011 JD 2520 Left Rear Marker Light #6
The service tech manual will be a good thing to have, one dealer service will pay for it, just sayin....
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
EPPS Powerhouse Pressure Washer (A55973)
EPPS Powerhouse...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
