Engine misfires
/ Engine misfires #1
rondele
great falls, va
JD LA140
JD140, started misfiring and did the usual things, new plugs and boots, fresh gas, new filters but no joy. But when blades are engaged it runs smooth.
Would adding an ounce or so of carb cleaner to gas be of any help? Don't have ability to do much more myself and shop is backed up this time of year.
/ Engine misfires #2
May be a spot of water down by the main jet. Rev it up and jam the choke on a time or two. That can suck the water through
/ Engine misfires #3
Are you sure that is is misfiring?
It would be strange that it would run good under load but not when the engine is not loaded. Are you confusing engine looping, i.e. engine speeding up and down with no input from the throttle?
What engine do you have?
Richard
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
(6) 250 Gal Chemical Containers (A64127)
(6) 250 Gal...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2025 SDlanch SDLD25 (A64127)
2025 SDlanch...
