Oil & Fuel YM2500 Pushing Coolant Out the Radiator
/ YM2500 Pushing Coolant Out the Radiator
Per the Fredricks UTDA agreement with Yanmar, they serialize the tractors on an ID plate riveted to the hood. I see the auction had S/N 2642. Are you saying you now own 2642 then.
Here is mine, 3661
I now wonder even more. Your machine has a lower S/N than mine. Did Fredricks do a buy back or help a customer trade up to another machine and took the YM2500 as a trade-in?
So much speculation on this S/N 2642 . . .
2,642 is the Hours on the hour meter of the tractor at the time of the auction, not the tractor’s Serial Number.
Here is a better picture of the numbers on the Transmission, and the Serial Number used in the auction on TractorHouse, which is an exact match of 02864.
The UTDA “Fredricks Importing” Tag Serial Number attached to the hood is 4465, but is difficult to see in the picture.
/ YM2500 Pushing Coolant Out the Radiator #164
I wouldn't have described the black smoke as soot, but that's me. The engine sounds a trifle uneven to me, but it picked right up when the throttle was tapped. In my experience, one, two, and three cylinder engines are never going to be as smooth or even as a four cylinder, much less an older engine vs one that has been through noise and vibration analysis with counter rotating balance shafts. I will admit to a soft spot for the old Lister one cylinder lug-lug diesels, but yes, they worked best when bolted to the continent, or a large boat.eah
I think that it is hard to armchair quarterback things from a distance. I am impressed at what Frederick's is doing for you.
All the best,
Peter
Yeah - tractor idling for goodness knows how long, then throttle blipped & a puff of black smoke is pretty normal I'd say. Try that with the average Lister & you'd be coughing for a week!
/ YM2500 Pushing Coolant Out the Radiator #165
All the best, Peter
***UPDATE 07-29-2025 Tuesday***
Positive News!
I received a text from my local tractor mechanic yesterday. He got the cylinder head back from the machine shop yesterday.
I asked what they told him about it and he stated, “It took a light pass to clean up 3 to 5 thousand.”
I asked him if that was good or bad and he stated, “Good”.
He has everything he needs now to put the Engine back together and everything needed to repair the Throttle Shaft Assembly.
It’ll probably be sometime next week before I’ll be able to pickup the tractor.
***UPDATE 08-02-2025 Saturday***
Everything is looking good!
My mechanic messaged me yesterday evening, stating that he got the Throttle Shaft changed, the Cylinder Head installed, and that he should finish it up this coming Monday.
He knows what he’s doing, there’s no question about that. But I’m still nervous and anxious. Fingers crossed!🤞
/ YM2500 Pushing Coolant Out the Radiator #168
Travis, since he is well versed in Deere/Yanmar engines, knows how to correctly work on diesel engines, I would like to add his shop on the YTOG for overhaul repairs. You would be surprised at how few get it right every time.
Mobiltech, LLC
7711 Hunstock Rd.
Denham Springs, LA 70706
Ray Myers @ (225) 413-4888
Current Business Hours as of 08/02/2025:
Sat - Sun: Closed
Mon - Thurs: 8:00 am - 4:00 pm
Fri: 8:00 am - 12:00 pm
***UPDATE Wednesday 08-06-2025***
Not good news at all.
I’m DONE.
My mechanic got the cylinder head and new head gasket installed and it’s still leaking coolant, from the same spot.
He said either the engine block will need machine work, or the tractor will need another engine! ((This would be the 3rd engine!))
I’ve had this tractor since November of 2024. The engines have NEVER been right since. (This is the 2nd engine!)
I have drove over 7 hours, one way, TWICE to Fredricks Equipment in Alabama to pickup this tractor.
The first time was when I initially purchased the “refurbished” tractor. The 2nd time was when I picked it up after “repair” when another engine was installed in it at Fredricks.
I sent Fredricks an email day before yesterday stating for them to come pickup the tractor from my mechanic’s shop and refund my money on the loan. They didn’t want to hear that!!
I got a reply from Stephen Fredricks the same day I sent the email, and he said to bring it to their shop for repairs.
I WILL NOT MAKE ANOTHER TRIP!!!
Fredricks owes my local tractor mechanic $1,802.70 for the Throttle Shaft Repair, the Cylinder Head Machine Work, and Labor.
I stated in the email to Stephen Fredricks that I do NOT want to seek legal advice, but I would if I had to.
I consider myself a Christian person and I do NOT want this to get ugly. I have NEVER faced a situation like this in my life. But I will NOT be crapped on either.
I think all of you understand that NONE OF THIS is my fault whatsoever.
I thought I was purchasing a refurbished tractor from a reputable dealer who I thought I could trust.
So my question is:
What would you do if you were in my shoes?
/ YM2500 Pushing Coolant Out the Radiator #172
Take it to them. Which I had a good idea how the warrenty worked. For me it would have been a few miles back to the dealer. No big deal at first. Then I went down. The YM2500 had a leak @ the hyd. pump seal. My guess the PTO. lift lock. We knew this and to repair it I would need to bring it in to the shop. Simple problem so I had my son drive me over.
Your mechanic done you a big favor! Problems that's not going to be able to be repaired. Eng.Block, Head etc.. Actually thought it was really odd they was paying a shop to do major repairs. My guess when they see it your going to be taken care of. Which seems to show that in trying to get it back in running condition. Of all the YM series the Ym2500 is a model to avoid for most people IMHO.. JD. eng. so it shows up often and then the PITA. 4 spd. PTO. gears. I hated that! SMH now. 2 shift levers :rolleyes:
/ YM2500 Pushing Coolant Out the Radiator #173
I think that what would be fair would be this:
1 Take the tractor back to Fredericks
2 Full refund for the original cost from Fredericks to you
3 Full refund of your mechanics costs to you
4 Payment to you for time & fuel for this last trip 7hrs each way.
I don't think it reasonable out of court to ask them to pay for the first or second trip, when they tried to fix the original problem, or the waste of your time.
HOWEVER
If you do use the legal route then I would certainly be looking to get payment for fuel & waste of time, loss of usage etc etc - I am sure a lawyer would not miss out on that to add to his percentage!!!
It would be much easier here in UK - we have a Trade Descriptions Act which has quite clear provisions for this sort of case & the supplier would not have a legal leg to stand on. One of the few things I can remember a govt actually getting right...
***UPDATE Thursday, 08-07-2025***
Myself, Stephen Fredricks, and my local mechanic Ray, have been emailing back and forth.
Fredricks has offered once again to come pickup the tractor at their convenience, at their expense, and bring it to their shop for “repair” (once again).
The mechanic(s) at Fredricks is who put the “copper RTV spray” on the cylinder head and block to begin with! Why would I trust them to work on the engine again??
The block is either gonna need machining down, or the tractor will need another engine. Period. Fredricks doesn’t seem to understand that.
My mechanic can do this job and I fully trust him. He would tear them engine down, send it to a machine shop, then re-assemble the engine.
Fredricks is not wanting to allow my mechanic to do the job.
I have all kinds of things running through my head because of this situation. It has caused very bad anxiety, loss of sleep, and bad dreams and nightmares. Not to mention the problems with my immediate family with me lashing out at them. Just so much on my mind!
I should be ashamed of myself.
Have a Blessed Day!
Travis
/ YM2500 Pushing Coolant Out the Radiator #175
Have a Blessed Day!
Travis
First off, I am sorry that you have had such problems and travails. I'm also sorry that the issues have caused friction with your family.
Ok. Down to brass tacks. Given what you have written above, Fredrick's seems to be offering in good faith to make this right. That is great.
Given the history, I understand that you trust your mechanic more than theirs, and I would too. As your mechanic Ray has been explicit with you about what the fix is, I presume at this point Frederick's knows as well what is needed for this block/head. However, I think that as Fredrick's is paying for the work, it is not unreasonable for them to use their own mechanic, but you might ask Stephen for a bit closer supervision of the mechanic(s). Much as I would love to get their mechanic(s) to commit to a plan of action in advance, that's not fair to whoever the mechanic is either, as they haven't seen the engine as it is now.
So, I would try to do a couple of things;
One, I think that you have the right perspective on family and tracts. I think that you may rely on the tractor, and you actually have money invested in it, but you are right this is a tractor, not an immediate family member needing to go to the Mayo Clinic. I think that you are right in family being more important than possessions.
Two, the goal here for both you and Frederick's is a working tractor. As far as I can tell from what you wrote above, you both seem to be on that page. That's great! I would let them do it.
Three, given the history, I think it is not unreasonable to ask nicely of Fredrick's, "if the currently proposed engine repairs don't result in a fully working tractor, what then?" It is a fairly polite way of getting across that you are frazzled, and would like to put all of this behind you for good. If the response is along the lines of "well, we will fix it again...", then I think it is worth pointing out what the track record would be at that point, and politely stating that given the time and effort, you expect them to make it right this time.
If the proposed repair doesn't fix things, I think I would cross that bridge when you get there. Sure, lots of things could go wrong in the future, but that's hypochondria in a different form. E.g. My current tractor blew a wheel motor at seven hours of runtime, (according to the service department the first time that they had ever seen the issue) and then blew the replacement motor at 22 hours, giving me back my rebuilt motor. At that point, I definitely had worries about what I had purchased. It has been fine ever since. So, my $0.02 is to hang in there.
I have been involved in taking things to court, (one big one was my employer had an issue ($$$ issue) with a supplier, and I was responsible for doing the heavy lifting with the lawyers). Trust me it is time that is lost from your life. If that's your profession, and you enjoy it, different story.
When Fredrick's sends you the repaired tractor, my $0.02 would be to baby it for a few hours. Don't use wide open throttle, don't lug the engine, don't short cycle the engine. Start it, use it lightly to do small chores for a few hours, and then stop. Then do it again a couple of times more to let everything settle in and bond.
As much as this saga has been frazzling, I would try to keep my eye on the prize; Frederick's (Stephen) is stepping up to make this right for you, and get you a working tractor.
All the best,
Peter
All the best,
Peter
Thanks Peter,
I needed to read that.
I’m just so frustrated and aggravated with this whole situation.
Here it is in a nutshell:
I purchased this “refurbished” tractor, from a reputable, trustworthy dealer of Vintage Yanmar Tractors in November of 2024. Was supposedly nothing wrong with it and was ready to go. That’s why I didn’t mind making the 7-8 hour trip (one way) to go buy it because of the Fredricks Reputation with these tractors.
That day back in November of 2024 when I loaded it on my trailer, I noticed transmission/hydraulic oil coming out the PTO Seal, the transmission Shifter Boot was all weathered and torn, and the Turn Signal Lights didn’t function.
The Salesman, Dan, told me to bring it down the road to Fredricks’ “Service Center”. Their Yanmar mechanic, Marti, changed the PTO Seal. Water was all in the oil so I asked him to drain the trans/hydro oil and install new fluid. He also diagnosed the turn signal lights and got them fixed with a new flasher unit. The parts manager, Danny, handed me a shifter boot and I installed it myself on the tractor.
Got it home and realized the head gasket was blown.
Fredricks agreed to let a local mechanic close to my house (who I know) install a new head gasket and a new head.
Fredricks sent a new loaded head. My mechanic started putting it back together with new (used) head bolts and said the tractor needed a new engine block because the threads where the head bolts went in the block were crooked. (My mechanic did not drill any holes or helicoil anything).
I paid my mechanic $200 labor for the dis-assembled engine. Fredricks was gonna pay him $200 to re-assemble, but my mechanic didn’t get to assemble it because of the bad engine.
Fredricks came and picked up the tractor in March of 2025 and installed a new, re-built engine (the engine that’s in it now). I had to go pick it up when it was complete.
I picked it up in April of 2025 and brought it home. I noticed the front gear case timing cover had a crack in it and was leaking oil. Fredricks agreed to let another local mechanic (whom I didn’t know) replace the timing cover. Fredricks paid for it, but I forgot off the top of my head what it cost. I will come back and edit once I find the price.
I get it home, use it for a couple hours bush hogging and noticed I had to add coolant. I looked for a leak and that’s where I found the 2 leaks coming from between the cylinder head, head gasket, and engine block. The throttle shaft assembly had to be replaced also, which Fredricks agreed to do.
Fredricks agreed for me to bring it to a local mechanic shop in my area (the one who replaced the timing cover).
He got it all tore down and noticed a huge amount of RTV Silicone Copper “gunk” on the cylinder head, head gasket, and engine block.
The cylinder head was sent off to a machine shop (standard practice by my local mechanic). 3 to 5 thousandths of an inch had to be milled down because of “gouges”. He repaired/replaced the throttle shaft assembly and installed the head back on the block. Torqued it all down to specs. Still leaking coolant. Re-torqued and the engine got to running temp and cooled down. Still leaking coolant from the same 2 spots. The bill for Fredricks is $1,802.70.
Fredricks assembled the “new re-built” engine that’s in the tractor now with all that copper RTV spray “gunk”.
Fredricks has offered to come pickup the tractor again for repair at their shop.
I told Fredricks I either wanted my money back on the loan and they can come get the tractor, let my local mechanic do the complete engine job, or bring me another tractor of equal value. I cannot make another trip up there over 7 hours one way, on my dime.
Why would I trust their mechanic(s) after they’re the ones who assembled this engine to begin with??
These are not the same mechanic(s) at Fredricks who were doing the refurbishments back in the day when the Yanmar gray market tractors were popular and when Fredricks had a yard full of them. One of them hasn’t been there but about 5 or 6 years.
So here we are now. I am waiting on their reply.
/ YM2500 Pushing Coolant Out the Radiator #177
UTDA Disbanded 10 Yrs. ago. I'm thinking yours wasn't refurbished and a local tractor dealer. Just a guess!! The refurbished YM2500 from Fredricks looked brand new. It was UTDA in 2009. Not a scratch on it. My Org. YM2000 I purchased in 2008 same dealer. The muffler and seat was replaced and still the only things not Factory org. today. Had the Starter Rebuilt I still use.
***UPDATE 08-15-2025 Friday***
I have decided to give Fredricks one more chance at making this right. Once again, they have offered to come pick it up.
The check from Fredricks is supposed to be in the mail to Mobiltech, for the Throttle Shaft Replacement/Repair and the Cylinder Head Job.
Fredricks said if the engine block turns out to be bad (which it is), they will once again build another new engine.
Regardless, I hope they do it right and get the engine block “decked.” I do not want ANY shortcuts.
***UPDATE Tuesday, 08-19-2025***
Rob Fredricks replied back to the email I sent Fredricks about the check for the repair bill on my YM2500.
He stated that the check was printed last Wednesday, and was mailed out last Thursday. Was sent by regular US mail, so there’s no tracking number.
It’s my guess that Mobiltech will be receiving the check either today or tomorrow. Should be anytime now, regardless.
…Stay tuned for more updates.
***UPDATE 09-01-2025 Monday***
Mobiltech received the check from Fredricks. I picked the tractor up at Mobiltech at the beginning of last week and brought it home.
I have to decide what I’m going to do.
Either I have to bring the tractor to Fredricks and they’ll return it for free after it’s fixed, when the have a truck coming this way (no timeframe), or Fredricks will come pick it up for free when they have a truck coming this way (no timeframe), and I’ll have to pick it up from their shop once it’s fixed.
Have a Blessed Day!
Travis
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
500BBL WHEELED...
84'' Skid steer bucket (A61567)
84'' Skid steer...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
