Snap Ring Pliers.
/ Snap Ring Pliers. #1
Alan W.
Kentucky
Kubota L3650 & Bobcat 763G & Craftsman DGS6500
I am looking for an external set that resembles this internal pair.
Due to clearance issues I need the 90degree bend and the extra long nose. Everybody sells this style in internal but no one it seems has an external variety.
Hopefully someone can help me find what I need.
/ Snap Ring Pliers. #3
I got a set off of amazon a few years back, work good, but necks arnt as long as the one in picture.
/ Snap Ring Pliers.
Im replacing the clutch assembly on a van without pulling the compressor.
All I have left to remove is the coil and due to the hole depth and proximity to the radiator none of my pliers will work. Surely somebody makes one.
/ Snap Ring Pliers. #5
I have a set which lets you flip it from expand to contract by moving the hinge pin. Weak link for me has always been the tips bending or breaking.
/ Snap Ring Pliers. #6
These may not be long enough
there are some very long nose straight ones; maybe you can use a torch to bend the tips, quench
/ Snap Ring Pliers. #7
My dad had an old set with removable tips, all different kinds of tips. Never knew where those went when i settled the estate. My brother probably stole them. Real heavy duty set too.
/ Snap Ring Pliers.
Yes I have a couple of those also. Tried modifying one of them to work but the assembly is too thick to get in the opening.
/ Snap Ring Pliers.
No tho tips are too short. Thanks
/ Snap Ring Pliers.
I have three different ones that take the changeable tips.
/ Snap Ring Pliers.
Its looking like I will have to make one by heating and bending a straight pair.
Hopefully the temper will hold.
/ Snap Ring Pliers. #12
I've had this set for years. Really versatile.
/ Snap Ring Pliers. #13
You might check the tool trucks you see at various businesses. I know they are expensive on their tools but I found what I needed years ago on a tool truck that came to my work place.
/ Snap Ring Pliers. #14
I invested in this 3 plier set from Lang Tools years ago. It cover such a wide variety of applications saves time/money. Each size plier has full set of tips that are interchangeable and each plier switches from internal to external. Has pretty much solved any situation I’ve been in. They also sell replacement tips. Check out their site, they have many more versions.
/ Snap Ring Pliers. #15
/ Snap Ring Pliers. #16
Amazon.com Not as heavy search for 90 degree heavy duty snap ring pliers.
/ Snap Ring Pliers. #17
/ Snap Ring Pliers. #18
Try Harbor Freight Tools. They have a couple choices.
/ Snap Ring Pliers. #19
Also, Tractor Supply has them.
/ Snap Ring Pliers. #20
MAC Tools must have offered a set at one time or another, as I have a large drawer full of all kinds of snap ring pliers, mostly MAC. The toolbox was owned by a friends Dad who owned a semi truck transmission and rear end shop. I have never needed a set of snap ring pliers that something in that drawer wouldn't fit!
David from jax
