Better Lynch Pin?
   / Better Lynch Pin? #1
Lucky Dog
Midland, MI
TYM 4820c
Is there anything more secure than this style of Lynch pin to the lower lift arms?
I keep losing them while brush hogging. I'm thinking about using a bolt and nyloc nut, but that would be a pain.
   / Better Lynch Pin? #2
   / Better Lynch Pin? #3
Perhaps in this specific situation, a pivot pin would be less likely to fall out? They come in all shapes and sizes.
There's also these crazy doo-dads, but I've not a clue what to call them:
   / Better Lynch Pin? #8
Here is one of John Deere's solutions for mounting a bucket, forks etc. onto a loader frame using a lynch pin. Pt No AW30903. Shown connected and in storage aka device change. Maybe it could be used in your application. Just info.
   / Better Lynch Pin? #9
   / Better Lynch Pin?
   / Better Lynch Pin? #12
Kubota makes a locking lynch pin - I use it on the coupler pin on my excavator buckets -- there are several versions - from 17 - 40$ each but they don't drop off like the standard ones -- I carry the standard ones as spares in all my equipment - as everything falls off eventually :)
   / Better Lynch Pin? #13
I have this same problem also. It only happens when using my Woods bush hog. I hope someone has a solution
   / Better Lynch Pin? #14
Tie a thin rope to a point on tractor around round part of pin , keeps my locking pin for quick coupler from getting lost , kevlar rope the best
   / Better Lynch Pin? #16
I used to lose mine all the time. I added a large washer on each side of the arm, then installed the pin. Haven't lost one since.
I have done the same thing on certain implements. In fact, after installing the large washers on the 3pt pins, i use larger hair pins and it works great. Finish mower and snowblower both seem to like it. I have not done so with the big rotary cutter yet.
   / Better Lynch Pin? #17
I converted my Woods brush hog to be quick hitch compatible, because I have the Deere iMatch quick hitch system on my tractor. It was as secure as could be, zero issues, and I'd imagine any other quick hitch would be similarly secure.
Bonus, it would only take about 30 seconds to mount or dis-mount my brush hog. :D
   / Better Lynch Pin? #20
The black ones are so good that if one of them snaps closed on your finger.....
well just be careful!
Every damn thing about working with farm equipment is trying to injure or kill us. We all know all the ways to be safe and careful, and we do that, and we still get hurt. Even our calm and gentle horses can suddenly step on our toes.
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
