Question for electricians
/ Question for electricians
Not sure how yours is setup. Mine has 2 separate meters and 2 separate CT’S set to read both phases. Mine reads Volts, Amps and frequency
The setup is:
-Power box is plugged in 50 amp generator outlet
-Cable from power box plugged in wall outlet connected to 50 amp
circuit breaker in the panel.
-There is manual interlock kit installed so generator serves whole house
/ Question for electricians #103
There's no owner manual
Do you have a clamp on ac meter?
I’m guessing it’s only equipped with 1 current donut, and is probably only valid amp and power readings for balanced loads.
If you want to see what it’s measuring, and you do have a clamp on, turn off all breakers except a 240 volt load like an active electric range, and see if the current measurement agrees . Then do the same test using only a 120v circuit on L1, finally another test using only a 120v L2 circuit.
This will let you see what your new unit is actually measuring.
Thank you! I'll try that
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
213089 (A64276)
213089 (A64276)
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
