DK45SE shuttle shift? And how to use it.
/ DK45SE shuttle shift? And how to use it. #1
part-time-Farmer-NC
Kioti DK45Se
Saw a post about another type of tractor that triggered a thought I have been wondering for some time. On my DK it has a forward/N /reverse shifter. Is this a the "shuttle Shifter" I read about?
So if I am doing bucket work and shifting between them (F/R) do I need to use the clutch? I honestly have never tried it. I've always clutched it.
Same thing for the 1-4 gears, l/m/h range? Can all those be changed "on the fly"?
/ DK45SE shuttle shift? And how to use it. #2
/ DK45SE shuttle shift? And how to use it. #3
A very quick search shows that it is a synchronization dry clutch shuttle. So, yes, you come to a stop or near stop, clutch, and shuttle into reverse. It isn't a power shuttle, or so, clutch each time.
Also, clutch to change gears. I "believe" you also have to come to a stop, and then clutch to change ranges (L/M/H).
You might need better advice, as some machines (some kubotas), have a GST, that allows changing gears, 1, 2, 3, 4, without cluthcing.
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
2025 FABRIQUE VICTV714TA2 T/A  14FT ENCLOSED TRAILER (A67148)
2025 FABRIQUE...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
