/ Harbor Freight Tools that don't suck #16,201
Far as I'm concerned their mid to high end welders and plasma cutters are all top shelf. I own multiplies of them and my employees use (and abuse) them daily and so far I've only had to return one unit and that was because the plasma cutter didn't come complete (no torch) and because I always buy their extended no hassle money back or replacement warranty, replacement was as easy as a 10 minute drive to my local HF store. Actually, if you buy their extended warranty, the warranty period is longer than any of the other main brands like ESAB or Miller or Lincoln and warranty return is much easier as well. No dealing with a service center, no waiting for a unit to be repaired either. Take it in and walk out with either a new one or a full refund.
Try that with any other player and report back...
/ Harbor Freight Tools that don't suck #16,202
Project Farm ranked HF's plastic oil change ramps at the top of his list.
I just bought them. I don't have anything as heavy as half the rated capacity.
These should work better than metal ramps, which tended to move when climbed.
Any comments?
I had a set the neighbor borrowed and never returned. Glad you reminded me...
/ Harbor Freight Tools that don't suck #16,203
I, for one, don't have any desire to use used ear plugs with ear wax on them, throwaway or not.
OK. - I dont seem to wax mine enough to notice before they are lost naturally somehow.
/ Harbor Freight Tools that don't suck #16,204
When you remove them, roll them between your index finger and thumb and look what is deposites on your fingers...ear wax.
Having said that I use Walker's Game Ears when hunting but I clean them after every use.
If you smoke a pipe (I don't) it's been said that ear wax makes a good pipe bowl dressing...lol
/ Harbor Freight Tools that don't suck #16,205
Any comments?
A few years back bought rhino brand ramps 16k lb capacity. After I noticed my class c RV was slightly bending my old steel ramps.. another point to my post believe the weight capacities of tools and equipment lol. if the hf ramps are like the rhino brand ramps I own they work good.and nest I'n each other for storage 16k rhino ramps aren't much more than the hf 6.5 k either. .
/ Harbor Freight Tools that don't suck #16,206
The hf pneumatic rivet gun definitely does not suck and was priced more than fair when I bought it around 15 yrs ago. Anyways rear apron/ deck underpinning was separating on.one of my boats/ pontoon, so I used he rivet tool and my hf cobalt drill index to repair. Over the years used it quite a bit on various projects and it's always performed as I expected it to. Mine came with various sized heads that store in bottom of rivet gun for different sized rivets. The cobalt drill bit index is also pretty decent at least for diy and bringing hair brained projects to life lol. Keeping in mind they aren't for daily professional use like higher end drill bits I've used before. The 12v small ridgid drill definitely in back ground is not good I have to use a a channel lock to tighten the chuck, won't waste my fumbling finger screen time ranting about all the battery problems I've had with it over the years.
/ Harbor Freight Tools that don't suck #16,207
Most everything that HF sells today in the upscale tool lines fails to qualify as suck tools.
Having said that I don't much care for the HF rivet assortments. Much better quality one are available elsewhere.
/ Harbor Freight Tools that don't suck #16,208
I use arrow brand rivets mostly, the 12volt drill is ridgid brand from hd I guess when they took the ridgid line they destroyed its reputation like I've seen on other tools out there. Only keep the small drill and other 12v ridgid tools cuz some times you need something that size to get into close qtrs.
/ Harbor Freight Tools that don't suck #16,209
When I bought that rivet gun I think they were in the trial and error transitioning phase of putting somewhat durable tools out there. In any case if one uses rivets for fastening somewhat frequently that gun is a must imo.
/ Harbor Freight Tools that don't suck #16,210
One thing noticeable is the hf Tools that don't suck suck has many more posts and is far more active than the opposite thread I remember seeing of hf tools that do suck I definitely contributed to both the sucky other thread definitely not so much anymore. Self proclaimed tool junkies like me need a decent tool store after sears demise.
CFG Industrial MH12RX (A60463)
CFG Industrial...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2012 HEIL (A60736)
2012 HEIL (A60736)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
