Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #16,181
Anyone have any experience with those hf extreme duty tarps and how long they last? Will be used year round permanently mounted for a roof on old greenhouse. Green house not used for growing anymore just storage. Approx 25'x22'.
If you mean the dark green canvas type ones, I've had one covering a trailer with a "soft top" for maybe four years now and it's still in perfect condition. Despite our brutal UV. Unlike the HF straps that are holding it in place.
   / Harbor Freight Tools that don't suck #16,182
I Assume that isn't a hf tarp Want cheap but somewhat longer lasting. If I was smarter and looking for a more permanent solution I'd probably buy corrugated steel $$$ and run it up the bows like a giant carport. That current plastic has been on at least before we bought the place 8 yrs ago and is starting to fail. To be honest never thought that commercial type greenhouse would still be standing especially when I moved the entire green house still erected 50-100 ft off the side of the pole barn. Could start a new thread but looking for a cheap hf solution. Lol
   / Harbor Freight Tools that don't suck #16,183
Have you looked at the various vendors selling the "billboard" materials.
   / Harbor Freight Tools that don't suck #16,184
It is indeed a HF tarp, but I don't remember how large they come.
Lucked out and had more than enough corrugated steel left over from the barn, hay barn, car port, etc. to cover a smaller trailer that I only had the bows for. When the good HF tarp expires. the other trailer will also get a steel roof.
   / Harbor Freight Tools that don't suck #16,185
Old buddy of mine worked for a bill board sign co. Gave me a ton of old printed on sign material years ago unfortunately not for seeing a use for gigantic sheets he gave me cut it up to make smaller tarps. I will say That stuff is strong and very resistant to weather.
   / Harbor Freight Tools that don't suck #16,186
Figure I need 25 long x40 wide for tarp, I should try and remember basic geometry to find the area of the bowed roof lol. For quite a while been looking for scrapped/used corrugated steel seems when I found some at an auction or similar it went quickly at a premium.
   / Harbor Freight Tools that don't suck #16,187
I will say that I've not had any HF tools that suck lately, but then I don't purchase any of their low buck stuff anyway. Always the higher priced tools.
One of my favorites in the Bauer corded finishing tool with the interchangeable drums. It allows me to change out drums for removing mill scale on ferrous metals but at the same time, removing oixidation from aluminum prior to welding (by changing out the drums, something you have to do when going from ferrous material to non ferrous material simply because if you don't, when welding aluminum, a ferrous drum would compromise the weld. Actually have my drums marked as to their use...and the Bauer tool is quite a bit less expensive than the competitors as well.
   / Harbor Freight Tools that don't suck #16,188
Are you talking about the surface conditioning tool? If so, I just bought the Hercules model of this tool a couple months ago.. I haven't even taken it out of the box yet. I have been buying different drums so I will be prepared for what's needed hen I get to that point.
   / Harbor Freight Tools that don't suck #16,189
Bought the Bauer when they first came out, looking at the Herc, it looks just like the Bauer I bought and got it on sale (ITC club) for less than 100 bucks with 3 drums included. I would caution you about one thing and that is... The gearbox is lacking sufficient lubricant inside and comes apart with Torx screws. I would suggest taking it apart, cleaning out the 'smooze' grease inside and replacing it with real grease is sufficient quantity.
Certainly was less that the Eastwood version which looks identical to the HF tool. Eastwood also want q uite a bit more for the drums.
Cleaning out the 'smooze' grease that HF has in their gearboxes is SOP for me, no matter what the tool is. HF likes to use 'smooze' grease in their gearboxes for some reason, but it is easy to take them apart and remove the smooze grease and replace it with 'real' grease.
The one exception I've found is their Chief air grinders which is an exact copy of the IR air grinder at about 100 bucks less. The Chief actually has good grease in the gearcase. It also comes with flush mount grease port on the frint of the tool, for adding additional grease if required. Same with the Chief air powered drill.
   / Harbor Freight Tools that don't suck #16,190
I got one of the last Bauer units for like $60 when they went on clearance a couple months ago. Seems they only have the Hercules now and it does not come with 3 drums which is a bummer.
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2024 JOHN DEERE 50 P-TIER EXCAVATOR (A52709)
2024 JOHN DEERE 50...
LOT: (48) 2.5 Gallons of Star Fire Diesel Exhaust Fluid (A59076)
LOT: (48) 2.5...
Bucket (A55973)
Bucket (A55973)
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
