Given the current prices in 2025, what are your thoughts on PT422 over PT425?
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #51
Take a shovel and pick up a shovel full of loose dirt. Then try sticking that shovel into compacted soil and lifting it. Same shovel.
Take a bucket on the PT and jam it into hard soil. It won't break free and the rear comes up off the ground.
Take a bucket on the PT and jam it into a pile of granulated limestone (like I did hundreds of times at the ball park). It's loose material. The rear of the tractor still comes up because it's too heavy for the tractor to lift, despite it being loose material. Similar with a pile of rocks, bags of cement, etc...
Once you hit that magic point where the tractor won't lift it and the rear wheels come off the ground it doesn't matter if it's 800# or 8000#... it's no additional strain on the machine.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #52
I use 2 different mini hoes (they are not Power Trac models) quite a bit. They definitely put a huge amount of stress on things the way I use them when digging through our hard clay and shale. The swinging one can put some sideways stress especially when using it to pull logs sideways out of the woods. I would not recommend doing that a lot. The other can dig I believe 6' down and has a 12" bucket. That is definitely a lot of weight and leverage.
Just a note about using skid steer attachments. I welded a plate to a skid steer adapter so I could use skid steer equipment on my 1850. I am guessing that must weigh 150 lbs. The attachments I have are fairly large and weigh between 800 and 1250 lbs. I doubt the 425 could handle these. They are pushing/exceeding the limits of the 1850.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #53
Welcome bel422! A past member “fourteen” was a big fan of reversing many things PT related, the stump grinder being one. He turned the blade around and reversed the hoses so the chips flung forward. I’m not saying to do it! He swore by it.
Kris
I've learned to keep the mounting plate between the bottom of the blade and my face. The plate blocks most of the flying debris. Also, go at the stump not from the top of it, but at, or slightly below, ground level into the side of the stump. Drive slowly forward and oscillate left and right.That keeps most of the debris on the ground. If on a slight hill, point downhill to let gravity pull you into the stump. If on a steeper hill, I find pointing uphill gives me better control, although you use the engine more.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #54
There is a lot of strain digging with a backhoe bucket, especially when rocks and tree roots are involved. PT mini hoe design appears to reply on turning the PT to dump material to the side. There are no outriggers on the mini hoe to distribute the force of digging to the ground.
One reason I dont own a 3pt backhoe is I was warned tractor rear ends have been known to break due to the forces involved.
On the PT "mini-hoe", I call excavator (because mine is not mini nor a backhoe) you dig with it by putting the bucket down where you want the hole, adjust the cutting angle and then back up the tractor to cut into the earth. The curl function (uncurl/dump) does not have enough power to pull the bucket through the dirt like normal one-use engineered machines (backhoe or hyd excavator).
No need for stabilizers/outriggers, there is no more stress then any other job where the tires loose traction .
It is a big compromise and hard to get used to. But better then a shovel. And think about how a standard front bucket is designed to push/cut it's way through a pile and how wide is it? 48" 60" ++ ETC. The mini-hoe is from 6-10" wide with teeth so all the same force that is available that pushes the full width bucket into the dirt but now concentrated to a few inches. They dig great, just cumbersome to work the controls cause they operate unlike any other machine I have used. The amount of weight of material in the mini-hoe bucket is insignificant for concern on sideways stresses, it might be 1 cubic foot or less compared to a heaping full loader bucket driving to load a dump truck/trailer.
I see the real problem is with the thumb allowing pic and carry work. The weight will easily be max for the machine and since you are moving about the dynamic forces can spike to extremes.
Other backhoe manufactures (and many other types of machines) have dealt with this for years by adding circuit reliefs. The closed loop with the spike loads now has an escape hatch - exit.
By memory from years ago, for example the system relief would have a relief setting of 2100 psi. The circuit relief was 3000 psi.
The valve themselves are currently $100 or so and you would only need 2 short -4 hoses and 4 fittings (for each circuit you want to protect). Cheap insurance. I intend to do it, maybe this winter. Here is an example Pardon Our Interruption...
Disregard the motor application, The cylinder diagram shown is what is needed.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #55
Nice list!
Just a note about the stump grinder. Very useful to grind stumps to ground level or lower. Can also dig holes. Quite messy, however, and it fills the front of the 422 with debris. I wear a full clear face mask as you can hurl stones inward. I've also hung a piece of an old tarp from hooks band clamped to the ROPS for more protection.
this is what I did to my stump grinder some old conveyer belt did the trick
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #56
Whatever works!
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #57
Power Trac is a very interesting machine but seems like almost everyday I’m reading about one that’s broke down somewhere and no parts available
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #58
Yes, I would agree with you that they are interesting machines, but the "...almost everyday I'm reading about one that's broke down..." I get an alert every time there is a post here. So, that seems a bit exaggerated to me. I think one downside to forums in general is that happy, satisfied, customers don't regularly login to say "Yup, still working..." I think that one great thing about TBN is the depth of expertise across the forum, and the incredible helpfulness of most folks here, for I am personally very thankful. So, it makes it easy to ask TBN when an issue comes up, because there isn't a "Bob's Power-Tracs" down the road in Wausau that one could phone up to ask. With PTs, one either asks the factory, or TBN, and in my experience both are excellent.
As an owner, I can say that yes, like any tractor, Power-Tracs do have parts break. More or less compared to others that I've operated? Not obviously so compared to the others, at least to me. But that's an N=1 personal opinion, and I've only worked with 8-10 tractors.
I would also say that in my personal experience, the factory has always had parts for me, and has even recommended 3rd party replacements for less. I've never been down for more than ten days. (Once) More frequently, I call the service department with a question or issue, and a replacement part is here before I can clear time to fix it, and we are on the opposite side of the country.
I've owned or operated a selection of tractors over the years (greens, blues, oranges, grey). I liked many of them for what I was doing, e.g. mowing, haying, drilling, plowing, and spraying. Some were exceptional; a Deutz comes to mind.
I will say that I know of no other brand or model of tractor in the world could have done what my PT-1445 has done here. Performance on slopes is phenomenal and the ability to switch up attachments makes it very very versatile.
I'm personally very focused on tractor safety, followed by utility. I've had three friends killed in rollover accidents, all on conventional style tractors, all trying to use them on slopes. One of them in your neck of the woods, and it was the end of the family farm. Kinda made an impression on me.
Horses for courses.
All the best,
Peter
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #59
All tractors, and all machines of any kind, will eventually break something. This is my personal experience. As my pt422 is my first experience with power-trac, some problems I've recently had were hydraulic leaks from 2 loose ports underneath the variable volume pump. Both just needed to be tightened with an Allen wrench, with some Permatex Green applied after tightening. But the secondary problem was the amount of fluid that leaked everywhere. Can't be good environmentally. I now park the machine on pieces of cardboard that will soak up any leaked oil, or put pieces of cardboard next to the rear wheels where remaining oil from the body flows out.
Other than that, I love that the machine has a low center of gravity, making it somewhat safer on hills. I do use the seatbelt, and you do need to take extra care always when you're sitting on any powerful machine.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #60
I wish my tub was THAT clean!! The only time I have fluid mess is when changing filters other than when both front wheel motors broke.
2018 Enclosed Trailer (A60352)
2018 Enclosed...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
HYSTER 50 FORTIS STRAIGHT MAST FORKLIFT (A59823)
HYSTER 50 FORTIS...
1660 (A59213)
1660 (A59213)
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
2005 Ford Excursion (A60352)
2005 Ford...
