Kubota 8540 gearbox pressure/heat
/ Kubota 8540 gearbox pressure/heat #1
MarkMCM
Arlington, TX
MF 275
M8540 3007 3800 hours
After running a seed drill for a couple of hours (drill raise and lower at end of each pass), checked hydraulic fluid.
When I pulled the dipstick, a geyser of hydraulic fluid shot out until I put the dipstick back in. Rear case was hot enough to melt the filler cap. Engine temp normal.
Thoughts?
/ Kubota 8540 gearbox pressure/heat #2
First thought is did you have one of remote levers locked in detent position or 3 point asking for raise all the time. Either of these would keep pump at relief pressure creating heat.
This based on your tractor having a gear pump.
/ Kubota 8540 gearbox pressure/heat #3
Pull type or 3 pt ? It’s easy to pop a remote lever into detent and not notice especially on a turn around trying to get lined up.
Thanks guys. I done that before with the detent. I didn't think I was today. I will run the drill again with that in mind.
/ Kubota 8540 gearbox pressure/heat #6
Glad it was a simple fix.
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
Kubota L2501 (A60462)
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
2014 18ft. Top Hat T/A Trash Trailer (A60352)
2014 18ft. Top Hat...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
