Kubota 8540 gearbox pressure/heat
/ Kubota 8540 gearbox pressure/heat #1
MarkMCM
Arlington, TX
MF 275
M8540 3007 3800 hours
After running a seed drill for a couple of hours (drill raise and lower at end of each pass), checked hydraulic fluid.
When I pulled the dipstick, a geyser of hydraulic fluid shot out until I put the dipstick back in. Rear case was hot enough to melt the filler cap. Engine temp normal.
Thoughts?
/ Kubota 8540 gearbox pressure/heat #2
First thought is did you have one of remote levers locked in detent position or 3 point asking for raise all the time. Either of these would keep pump at relief pressure creating heat.
This based on your tractor having a gear pump.
/ Kubota 8540 gearbox pressure/heat #3
Pull type or 3 pt ? It’s easy to pop a remote lever into detent and not notice especially on a turn around trying to get lined up.
Thanks guys. I done that before with the detent. I didn't think I was today. I will run the drill again with that in mind.
/ Kubota 8540 gearbox pressure/heat #6
Glad it was a simple fix.
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
(1) UNUSED 31" X 8 MM EXCAVATOR TRACK W/ PIN (A60432)
(1) UNUSED 31" X 8...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
UNUSED IRANCH HYD THUMB CLAMP (A60432)
UNUSED IRANCH HYD...
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
