Tractor Supply Cat 1 Quick Hitch cheap!
   / Tractor Supply Cat 1 Quick Hitch cheap! #1
HP942
Poplar Bluff, MO
LS XJ2025H
Anyone looking for a budget friendly quick hitch, check out this one i just bought from Tractor Supply.
   / Tractor Supply Cat 1 Quick Hitch cheap! #2
Just ordered mine. Can't beat the price for a Cat I. I hope it's as good as the Speeco E-Hitch (per its reputation). Reviews were strong, though more than a few said some or all of the connections were too thick or off by 1/4". Crossing my fingers.
   / Tractor Supply Cat 1 Quick Hitch cheap! #3
I don't see it listed on the TSC website.
   / Tractor Supply Cat 1 Quick Hitch cheap! #5
The video guy talks about the latch handles being bent down, that's just the handles mounted improperly. Turn them over and the curve is up to prevent pinching fingers.
I investigated these quick hitches and compared measurements to my CAT 1 equipment. I only have 2 attachments that will match up to a quick hitch without changing something.
   / Tractor Supply Cat 1 Quick Hitch cheap! #6
At that price, would be good to buy one and add JD hooks/pins or a QA and make a loader-mounted quick hitch. When I bought my HF QH many years ago for this project, they were really cheap, like $69 or something.
   / Tractor Supply Cat 1 Quick Hitch cheap! #7
I originally purchased a QH like this one and then bought the Pat's which I like much more than this style of hitch.
   / Tractor Supply Cat 1 Quick Hitch cheap! #8
I did this also with a HF QH. I don't use it a lot but it gives you great lift range with a boom pole and it's nice to back up trailers driving forward.
   / Tractor Supply Cat 1 Quick Hitch cheap! #9
I use it a lot with the carryall on the front and to move around 3-point equipment. Yes, great for moving trailers.
   / Tractor Supply Cat 1 Quick Hitch cheap! #10
Tried those, didn't flip my skirt much. Once i went to Pat's Quick connect system never looked back.
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A55851)
2016 Toro...
2012 John Deere 7230R (A55302)
2012 John Deere...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A55745)
MCELROY 500 SERIES...
