Hydraulic SSQA idea
/ Hydraulic SSQA idea #41
I didn't build that. Its someone else's video, but its something that I'd like to do to my machine. If you had to buy everything new, I'd say the total cost is well under $200. Probably under $100, especially if you use the $40 amazon actuator (current price is closer to $45 IIRC).
Yes I know, I wasn't sure if you had priced out all the components yet.
/ Hydraulic SSQA idea #42
Get the $120 actuator rather than $50 one. The cheap one is a bit to slow or weak, depending on which cheap one you get.
/ Hydraulic SSQA idea #43
I definitely wouldn't cheap out on a linear actuator in that application, I already have my hyd. one so not in the market.
You need to hurry up and finish yours, the hard part is already done! You'll wonder why you waited once you use it.
/ Hydraulic SSQA idea #44
Gotcha, sorry. I did some initial pricing just to get a quick idea of what kind of budget I'd need. I think it could easily be done for $100. On the flip side of that coin, a person could go with an IP67 cylinder and add enough connectors, cable loom, machined hardware, and other features to get the budget up closer to $1k. It just depends on how fancy you want it and what you already have on hand. Personally, my budget would be $100, but I also think you could do it AND have it look good and still be well under $200.
/ Hydraulic SSQA idea #45
I use a manual ball valve on my trailer to switch between tip and brakes. The trailer is plugged into the tractor remote(proportional) so is operated from a handle in the cab. Both the tip cylinder and brake cylinder are single acting(heavy internal spring in the brake cylinder to release) The tip cylinder just relies on the weight of the body to lower it. Both work fine and the manual ball valve holds the pressure with no bleed down. Most John Deere's, especially the older ones are closed centre so that might help too.
/ Hydraulic SSQA idea #46
I considered an electric one but just liked the idea of a manual one.
To me, it defeats the purpose. You either connect manually, or you connect hydraulic. If i have to leave my seat to turn the lever, i might as well turn the securing pin lever..
/ Hydraulic SSQA idea #47
As old as I am (76), I'll never become so lazy I have to have my SSQA pins automated to insert or remove. Manually engaging them gives you the opportunity to inspect everythimg to insure everything is 'kosher' up there...
/ Hydraulic SSQA idea #48
I don't think you understand, you don't have to get out of the seat operate the QA, only to switch from QA to remotes which you have to hook up manually anyway.
/ Hydraulic SSQA idea #49
it's the greatest thing since sliced bread. especially if you have to remove the loader attachment to fit in the shed. and as long as the attachment doesn't need the third function you just leave your valve set to the QA. Once you try it you will never go back.
/ Hydraulic SSQA idea #50
Then why not hook up the bucket manually too, when youre out of your seat anyway ?
Its been 20 years since i built my QA, i have the 4th function on the valve block (from an old feed mixer) but to me it turned out it just isnt worth it.
Once the grapple comes off and you are now just switching attachments that don't require the 3rd function, you no longer need to leave your seat to do anything up front. The hydraulic QA will do everything for you, so you can swap through all those attachments from your seat.
/ Hydraulic SSQA idea #52
Exactly, I switch between forks and bucket regularly. Also comes in very handy when loading/ unloading the ssqa implements on and off the trailer when I need to transport or move them around.
/ Hydraulic SSQA idea #53
You don't need an electric to go on the loader.
You leave the diverter in the ssqa position and use your 3rd function to actuate the ssqa.
If you mount an implement such as a grapple, you would mount it, get off the tractor, hook up your hydraulics hoses, then switch the diverter to the quick couplers for the implement and leave it in that position until you are ready to remove it.
Then, you would disconnect the hoses, switch the diverter back to the ssqa, and detach the implement from the seat.
No need to get off to switch the diverter, unless you have to hook up hoses, which means you'll be off the tractor anyways.
Only reason to run a second set of lines to the front is if you want to be able to run 2 cylinders on an implement from the 3rd function from the seat.
Exactly my thoughts.
Kubota Hydraulic SSQA Kit with Multiplier hydraulic quick attach
SELF-PRIMING CENTRIFUGAL PUMP (A65643)
SELF-PRIMING...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (Trailer NOT included) (A63689)
Denyo DCA-600SPK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
